    N64 Audio problem
    n64audio problem
    6 Posts 2 Posters 1.0k Views
    • N
      Niklassen
      Pi model: 3b plus
      Power supply: Ipad air 2 AC adapter. (I know that is causing it to get under-voltage throttled, but i will buy a better AC soon. That can't possibly be the cause. )
      RetroPie version: 4.4
      Built from: i flashed the RetroPie image with Etcher. Image file name (retropie-4.4-rpi2_rpi3)
      USB Devices used: i used a wireless Logitech keyboard once, just to connect my controller to BT.
      Controller used: IPEGA PG-9055, and a 8bitdo SNES controller.
      I built a portable retropie machine, with a screen connected and a ipega stretchable controller.
      My problem: Volume. I get sound from the AUX input. (And yes, I did select AUX in the sound settings) System volume does affect all emulators, except the n64 emulator. Audio is automatically set to full, and changing my system volume does nothing. This problem does not exist on any of my other emulators.
      HHHEEEELLLPPP! I WANNA PLAY SM4 WITHOUT EARAPE
        mitu Global Moderator @Niklassen
        @Niklassen said in N64 Audio problem:
        You mean you get sound from the 3.5' jack output ? What emulator are you using ?
        • N
          Niklassen @mitu
          @mitu Yes, and I use the default n64 emulator.
            Which is ...?
            N 2 Replies Last reply Reply Quote 0
            • N
              Niklassen @mitu
              @mitu I have no idea XD I thnk you would know.
              • N
                Niklassen @mitu
                @mitu ok then, mupen64plus
