    WiFi issues after attaching Controlblock on a Pi 3b+
    3b+ stretchcontrolblock2wifi problem3b+stretch
    4 Posts 3 Posters 967 Views
      SuperPitendo
      Hey Community!
      I ran recently in an issue with the Controlblock and the Pi 3B+. I have no wifi connection if the Controlblock is attached. Anything (incl. WiFi) works fine without the Controlblock.
      I use the latest release of RetroPie (4.4 Stretch), have the original power supply and a Samsung Evo+ 64GB SD Card and the Controlblock2.
      I used 3 different ways to get my WiFi to work without the Controlblock:
      1. Via RetroPie-Menu --> Success
      2. Via wifikeyfile.txt --> Success
      3. Via wpa_supplicant.conf --> Success
      If I do that with an fresh install and an attached Controlblock:
      1. Via RetroPie-Menu --> Unable to connect
      2. Via wifikeyfile.txt --> Unable to connect
      3. Via wpa_supplicant.conf --> Unable to connect
      I also used a pre-made image from petrockblock (Stretch 4.4 with the Controlblock driver preinstalled) but also with no success...
        edmaul69 @SuperPitendo
        @SuperPitendo what is the volts and amps output on your power supply and what type of power supply is it?
          SuperPitendo
          Original Raspi power supplywith 5V 2.5A.
          This is a hardware setup that already worked before with wifi. I didnt change anything (hardware and software). From one day to the other the wifi stopped working...
            petrockblog Global Moderator
            Hi, did you get my email reply?
