    Raspberry Pi Won't Boot, Red Power Light Only
    pi 3errorsred light
    12 Posts 5 Posters 9.6k Views
    • N.A.R.E.K.96N
      N.A.R.E.K.96
      I installed fan on my new raspberry pi 3 b+ and after it pi is not working. I know how to install fan and done it before so it must not be reason but after that my pi is not working anymore. I tried different sd cards and systems such as Raspbian, Recalbox and of course Retropie and without any result. My power supply is working fine with pi 3 model b I have and sd cards also . Only red light is working and fan :(
        If none of those images are working, then maybe the problem is the hardware. Which RetroPie image have you tried to boot ? How did you installed the FAN ?
        • N.A.R.E.K.96N
          N.A.R.E.K.96
          https://www.raspberrypi.org/downloads/raspbian/
            mitu Global Moderator @N.A.R.E.K.96
            @N-A-R-E-K-96 If you remove the FAN, does the PI boot from the SD card ? I think you don't have enough power for the PI + Fan available. Look over the official documentation to determine what could possibly cause the problem.
            N.A.R.E.K.96N 1 Reply Last reply Reply Quote 0
            • N.A.R.E.K.96N
              N.A.R.E.K.96 @mitu
              @mitu No it is not working just red light
              • N.A.R.E.K.96N
                N.A.R.E.K.96
                It looks like I accidentaly damadge microSD slot , I am not sure but i made mistake and tried to inser pi into case without removing sd cars, it was stupid but I done it
                • N.A.R.E.K.96N
                  N.A.R.E.K.96
                  You can see what it looks like in this photos
                  http://i97.fastpic.ru/big/2018/1105/20/_5e5916d3096a50b7bfba5798ec2c2020.jpg
                  http://i97.fastpic.ru/big/2018/1105/82/_2f79fce2346e13baa09ec0955c328882.jpg
                  http://i97.fastpic.ru/big/2018/1105/20/_3b105e7c7cd42518ce903d549a8aef20.jpg
                  • N.A.R.E.K.96N
                    N.A.R.E.K.96
                    Can someone at least tell me I broke my pi or not ? I upload photos so you can have a look , if it is broken I must buy new one
                    rbakerR 1 Reply Last reply Reply Quote -1
                    • ballboffB
                      ballboff
                      sounds like you fried your sd card, reflash and try again. I've done this recently, and some incorrect settings in the config.txt file can cause it not to boot. When the software is loading you will get a green light, so if you don't get the green light it suggest the software is at fault. Few weeks back I managed to disintegrate my sd card somehow as I think there was too much voltage running through my pi, I replaced my sd card after prizing out the old card with a pair of tweezers (There was only about 60% of the card left in the socket!)
                      • rbakerR
                        rbaker @N.A.R.E.K.96
                        @N-A-R-E-K-96 said in Raspberry Pi Won't Boot, Red Power Light Only:
                        try this checklist
                          grant2258 Banned
                          another rookie mistake is to burn the gz instead of the img this wont matter if you user etcher do burn the image
                          • N.A.R.E.K.96N
                            N.A.R.E.K.96 @rbaker
                            @rbaker I checked it and nothing helped , I used brand new Kingston microSD card so it must not be reason . Anywan I will buy new one during black friday I just want to know now , can I use Pi 3 Model B heatsinks with Pi 3 Model B + if so I ahve some of them
