    Problem configuring arcade controls
    button helparcade controls
    4 Posts 2 Posters 674 Views
    • I
      ivankahl
      Hello
      Pi 3b+
      2.1a charger
      4.1
      Built From: SD Image
      USB Devices connected: Keyboard and Arcade buttons and joystick
      Control
      Error messages received:
      Guide used: (Mention if you f
      Emulator Snes
      Im using arcade controls, 2 joystick and 6 buttons each plus 4 more (select, start and 1p 2p) but they got only one encoder for both. It associates each button to a letter in the keyboard.
      The problem is when i configure the controls inside the emulator some controls work but others seems like are preconfigured to do other stuff (as is being detected as keyboard) like stop the game or press record etc... like if they are doubled up.
      Where can i change those to something else so i dont have this problem? Thanks
      • rbakerR
        rbaker @ivankahl
        @ivankahl said in Problem configuring arcade controls:
        I installed a 64gb retropie Ultimate
        Third party images are not supported, you should ask the creator. See point 5 of https://retropie.org.uk/forum/topic/3/read-this-first
        Also when requesting support, if you use the official image , you need to post the info requested. In your post above you are asking questions about the "emulator" of which there are many.
        • I
          ivankahl @rbaker
          @rbaker sorry mate i understand now, i was thinking in actual image like photos.
          Updated post
          • rbakerR
            rbaker @ivankahl
            @ivankahl What image are you installing? How did you install it? This matters because nobody can second guess a third party and the current image is 4.4 - you say 4.1?? Only the official image is supported. Second, you cannot use a charger to reliably power a raspberry pi, especially that one as you need a minimum of 2.5A at 5V. Finally, which SNES emulator are you using, there are 7!?
