    Why separate Neo Geo system from Arcade?
    aesfbahistoryneogeotutorial
    42 Posts 12 Posters 23.6k Views
    • L
      luckyluca
      I'm using fb-neo, and had my core-options set to fbneo-neogeo-mode = "DIPSWITCH"
      It appears as if it behaves like MVS, but for safety, I'm thinking of changing it to MVS for the arcade.
      When making a copy of the core options to neogeo-core-options.cfg and changing to AES as suggested, should I also copy and add all fbneo core lines (there are plenty including lots of per-game dipswitches, one for each game executed)?
      Also, would it be problematic using a rom not ending with h in AES neogeo mode?
      thelostsoulT 1 Reply Last reply Reply Quote 0
      • thelostsoulT
        thelostsoul @luckyluca
        @luckyluca said in Why separate Neo Geo system from Arcade?:
        It's been a while when configuring it, I had just copied the entire file and made it act like an independent emulator. I actually don't know if RetroPie or fbneo will look for in "/opt/retropie/configs/fba/" first, if you load up a game from Neo Geo systems folder. If that is the case, then you can only include the differences you want to have in "/opt/retropie/configs/neogeo/neogeo-core-options.cfg" . If RetroPie requires you to have two different files, then you are probably out of luck.
        Or you can try to use the "include" statement on top of the neogeo-core-options.cfg to point to the file from fba. But I don't know if this works.
        As a sidenote, when looking through my old Raspberry Pi 3 installation backups, I don't see any neogeo-core-options.cfg files anymore, but retroarch-core-options.cfg. Not sure if the tutorial is outdated. Sorry for the late reply and I hope you get it working.
        Not at all. This was just my personal decision to use these specific versions of the ROMs. Although I couldn't spot any differences tbh
        πŸ“œ RE/SET: 100 SNES Games for your RetroPie, 🎁 Share your hidden gems and insider tips
