    Pi3+ low speed sdcard?
    sdcardpi3modelb+speed
    2 Posts 2 Posters 587 Views
      adiif1
      Hello all i have small problem with my samsung evo plus 128 gb
      Pi Model or other hardware: pi3+ A
      Power Supply used: Huawei charger 5v 4A
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.4
      i try add this line ( dtoverlay=sdtweak,overclock_50=100 ) on config.txt in folder boot
      CONFIG:
      CLOCK : 93.333 MHz
      CORE : 560 MHz, turbo=0
      DATA : 512 MB, /root/test.dat
      HDPARM:
      Timing O_DIRECT disk reads: 76 MB in 3.03 seconds = 25.07 MB/sec
      Timing O_DIRECT disk reads: 76 MB in 3.03 seconds = 25.05 MB/sec
      Timing O_DIRECT disk reads: 76 MB in 3.04 seconds = 25.02 MB/sec
      WRITE:
      536870912 bytes (537 MB, 512 MiB) copied, 42.0933 s, 12.8 MB/s
      536870912 bytes (537 MB, 512 MiB) copied, 41.2795 s, 13.0 MB/s
      536870912 bytes (537 MB, 512 MiB) copied, 41.8316 s, 12.8 MB/s
      READ:
      536870912 bytes (537 MB, 512 MiB) copied, 19.822 s, 27.1 MB/s
      536870912 bytes (537 MB, 512 MiB) copied, 19.7886 s, 27.1 MB/s
      536870912 bytes (537 MB, 512 MiB) copied, 19.7707 s, 27.2 MB/s
      RESULT (AVG):
      Overlay config core_freq turbo overclock_50 WRITE READ HDPARM
      560 0 93.333 MHz inf MB/s inf MB/s 25.05 MB/s
      • markyh444M
        markyh444 @adiif1
        @adiif1 said in Pi3+ low speed sdcard?:
        Phone chargers do not supply enough stable current to power a Pi. You need to get a dedicated PSU designed for the Pi.
        Retropie in a PSX - Pi3
