    Pc-Engine/Turbografx 16 multi-tap
    pc engineturbografx16multitap4 playerhelp retropie
    2 Posts 2 Posters 702 Views
      A Former User
      Hello,
      I am curious about how I can play 4 player Pc-engine games. Can I just use the USB ports on my Raspberry Pi, or do I need to configure something?
      Breadbin
        mitu Global Moderator @A Former User
        @Breadbin As long as the system has 4 working controllers (regardless of how they're connected), it should work. The only possible configuration would be in the emulator options, to enable multi-tap if it's not the default.
