    SteamLink for Raspberry Pi Released
    steamstreamingmoonlightsteamlink
    75 Posts 23 Posters 32.3k Views
      psyke83 Global Moderator @Darksavior
      @Darksavior said in SteamLink for Raspberry Pi Released:
      Looks like entering retropie-setup removes the xorg legacy package. Is there a way to get it working with the latest xorg package? I was getting permission problems with that one.
      Fatal server error: (EE) xf86OpenConsole: Cannot open virtual console 2 (Permission denied)
      Xorg and steamlink should be working correctly without the legacy package (which needs to be removed due to permission issues with Xorg.wrap). I think we'll need more details than a single line to troubleshoot your issue.
      • DarksaviorD
        Darksavior @psyke83
        @psyke83 AH, nevermind. Fixed it. Removed xorg and all its dependencies and reinstalled it all. Works now. No idea why it had permission problems in the first place. I'm using the official image.
        • DarksaviorD
          Darksavior
          @psyke83 In reinstalling the xorg package, it was also reinstalling the legacy stuff so then my problem restarted. So now I've uninstalled xorg, auto removed the remaining unused packages, and uninstalled the steamlink app. I then reinstalled the steamlink app and let that install the dependencies. Same permission problem. Here's the log.
          https://pastebin.com/B0x2qCig
          Legacy was working fine because I edited /etc/X11/Xwrapper.config and added allowed_users=anybody but that only exists for the legacy version?
            I'm seeing some oddities in your Xorg log. Did you enable the experimental GL (fake/full KMS) driver?
            Can you show a more complete list of xorg-related packages you have installed? Mine, for reference:
            dpkg -l | grep xorg
            ii  xorg                                  1:7.7+19                            armhf        X.Org X Window System
            ii  xorg-docs-core                        1:1.7.1-1                           all          Core documentation for the X.org X Window System
            ii  xorg-sgml-doctools                    1:1.11-1                            all          Common tools for building X.Org SGML documentation
            ii  xserver-xorg                          1:7.7+19                            armhf        X.Org X server
            ii  xserver-xorg-core                     2:1.19.2-1+rpt1+deb9u2              armhf        Xorg X server - core server
            ii  xserver-xorg-input-all                1:7.7+19                            armhf        X.Org X server -- input driver metapackage
            ii  xserver-xorg-input-libinput           0.23.0-2                            armhf        X.Org X server -- libinput input driver
            ii  xserver-xorg-input-wacom              0.34.0-1                            armhf        X.Org X server -- Wacom input driver
            rc  xserver-xorg-legacy                   2:1.19.2-1+rpt1+deb9u2              armhf        setuid root Xorg server wrapper
            ii  xserver-xorg-video-all                1:7.7+19                            armhf        X.Org X server -- output driver metapackage
            ii  xserver-xorg-video-amdgpu             1.2.0-1+b1                          armhf        X.Org X server -- AMDGPU display driver
            ii  xserver-xorg-video-ati                1:7.8.0-1+b1                        armhf        X.Org X server -- AMD/ATI display driver wrapper
            ii  xserver-xorg-video-fbdev              1:0.4.4-1+rvt+b1                    armhf        X.Org X server -- fbdev display driver
            ii  xserver-xorg-video-fbturbo            1.20170324~143242                   armhf        X.Org X server -- fbturbo display driver
            ii  xserver-xorg-video-nouveau            1:1.0.13-3                          armhf        X.Org X server -- Nouveau display driver
            ii  xserver-xorg-video-radeon             1:7.8.0-1+b1                        armhf        X.Org X server -- AMD/ATI Radeon display driver
            ii  xserver-xorg-video-vesa               1:2.3.4-1+b3                        armhf        X.Org X server -- VESA display driver
            • DarksaviorD
              Darksavior @psyke83
              @psyke83 I installed the complete xorg package (which turned out to be the legacy one) at one time but never enabled GL. The only xorg stuff I have installed now are through whatever the steamlink app installs.
              • DarksaviorD
                Darksavior
                Problem solved for real. Not sure what it was since I got sick of changing permissions for xorg-related folders with no results. I changed the dev folder's permission and everything in it and that did it.
                • SwampyS
                  Swampy
                  SteamLink was updated to 1.1.30:
                  https://steamcommunity.com/app/353380/discussions/6/3362406825533076063/
                  Will it be updated in RetroPie too?
                  Linux is like wigwam: no Gates, no Windows and Apache inside.
                    mitu Global Moderator @Swampy
                    @Swampy steamlink is installed from the Raspbian repositories, so whenever the update is released on their repositories, it will be available for update in RetroPie also.
                      psyke83 Global Moderator @mitu
                      @mitu said in SteamLink for Raspberry Pi Released:
                      You're right - keeping in mind that, similar to the Linux .deb for steam, the package functions only as a bootstrapper to fetch the latest release during launch.
                      Unfortunately, the bootstrapper also handles dependency resolution which usually requires user input to confirm via command-line when new packages are to be installed; the effect would be that you'd be stuck on the runcommand dialog.
                      The new release doesn't seem to have this problem, but it can potentially happen in future. If/when it does, I'll add the dependencies to the scriptmodule.
                        r3ddvil @thezoof
                        @thezoof Hi, having the same issue, I am pretty newb when it comes to Rpi script editing , but I added "steamlink" and "streaming_client" to the list of emulators in the music.py, and have reset the system and disabled/enabled audio and no luck for me. How do I rerun the script? Thanks.
                          backstander @r3ddvil
                          @r3ddvil
                          I think it's just called "steam"
                          • SwampyS
                            Swampy
                            The controller doesn't work in emulationstation any more after exiting steamlink inside. This happens since the latest update of steamlink. I don't know weather it is a problem with RetroPie or steamlink. Steamlink installs new udev rules. Perhaps, this could be the problem.
                            I mentioned the problem in the steamlink forum too:
                            https://steamcommunity.com/app/353380/discussions/6/1737760710137252830/
                            • SwampyS
                              Swampy
                              For now I have downgraded to version 1.1.45.105:
                              STEAMLINK_DATA_HOME="${XDG_DATA_HOME:-$HOME/.local/share}"/SteamLink
                              echo "file://$STEAMLINK_DATA_HOME" >"$STEAMLINK_DATA_HOME/update_url"
                              echo "http://media.steampowered.com/steamlink/rpi/steamlink-rpi3-1.1.45.105.tar.gz" >"$STEAMLINK_DATA_HOME/public_build.txt"
                              seen in https://steamcommunity.com/app/353380/discussions/6/1660069015242109357/
                              and in https://steamcommunity.com/app/353380/discussions/6/3681064390585946947/
                              Then I also added " --skip-update" in the last line after "/usr/bin/steamlink" in "/opt/retropie/ports/steamlink/steamlink_xinit.sh".
                              Now it works again for me.
                              • SwampyS
                                Swampy
                                The problem is solved with the newest version 1.1.50.
                                  Jste84
                                  Has anyone had any issues with audio?
                                  My audio seems to work on launch of steamlink. Then stops suddenly during a game.
                                  It seems to mute the volume during the game. Easy enough to put back on the laptop... But can't seem to do it in game? Can anyone help?
