    No Wifi Menu on Raspberry Pi 3 B+ Running Retropie 4.4
    wifi configwifi problemretropie 4.4wifi
    3 Posts 3 Posters 1.6k Views
    • O
      Otter22
      Hi,
      I'm new to the world of Raspberry Pi and RetroPie. I am in the process of setting up a Raspberry Pi as a game emulator.
      I have looked at numerous videos on how to set up the wifi and I do not have the same menus that I see in any of these videos. There are zero options to set up wifi.
      Using Emulationstation v2.7.5RP the menu is as follows:
      Scraper
      Sound Settings
      UI Settings
      Game Collection Settings
      Other Settings
      Configure Input
      Quit
      Any help would be much appreciated as I would really like to get this going! Thanks.
      • Azza292A
        Azza292
        If you can plug in a keyboard, press F4 to access the terminal.
        Once there type raspi-config, this should bring up an interface to set up your WIFI.
          mitu Global Moderator @Otter22
          @Otter22 The Wifi is not setup from Emulationstation, but via the RetroPie-Setup. You should have a WiFi menu entry in the RetroPie system in Emulationstation - just like it's described in the Docs.
