    Modify Power Button Behaviour to 'Hold for three seconds'??
    retropieshutdownpythonscriptdelay
    3 Posts 2 Posters 778 Views
      Chillimonster
      Im using the following shutdown script, but its susceptible to false triggers (Or shutdown if you catch the button etc)
      Is there a way to make it wait until the button has been pressed for a period of time (Say three seconds)
      I'm running Retropi 4.4 on a Pi3B+
      **#!/bin/python
      import RPi.GPIO as GPIO
      import time
      import os
      #gpio_pin_number=YOUR_CHOSEN_GPIO_NUMBER_HERE
      #Replace YOUR_CHOSEN_GPIO_NUMBER_HERE with the GPIO pin number you wish to use
      #Make sure you know which rapsberry pi revision you are using first
      #The line should look something like this e.g. "gpio_pin_number=7"
      GPIO.setmode(GPIO.BCM)
      GPIO.setup(3, GPIO.IN, pull_up_down = GPIO.PUD_UP)
      def Shutdown(channel):
      	os.system("sudo systemctl poweroff")
      GPIO.add_event_detect(3, GPIO.FALLING, callback = Shutdown, bouncetime = 2000)
      while 1:
      	time.sleep(5)
      GPIO.cleanup()
      #Revert all GPIO pins to their normal states (i.e. input = safe)**
        You can increase the bouncetime from 2sec to something larger.
          Chillimonster @mitu
          @mitu said in Modify Power Button Behaviour to 'Hold for three seconds'??:
          Even as it is now, just a single quick push will shut the software down - i dont have to hold the button at all.
          Perhaps I need to use a different script that relies on the button being held.
