    lr-mame core reset with joypad using default hotkey settings doesn't reset core
    mameresetlr-mamex86hotkey
    1 Posts 1 Posters 346 Views
      movisman
      Hi all,
      I know not many will use this core, but was wondering if anyone here who might be using "lr-mame" (mostly x86 users as it doesn't work well on Pi!) has an issue resetting the core in the usual default way of hotkey + B (snes controller example).
      For me, the reset message comes up at the bottom left, but the core doesn't reset, it just carries on running.
      If I plug a keyboard in I can reset the core with the MAME default, which is one of the F keys (can't remember which right now!).
      Other options work fine with hotkeys on the joypad (quit, save/load, etc). On all other libretro cores I use (10+), the core reset using hotkey + B works exactly as intended. It is just this MAME core which is troublesome.
      Is anyone else able to test this to see if they get the same thing as me?
      For reference, my install is reasonably fresh and I haven't messed with specific MAME settings except config files for overlays. I haven't accidentally programmed an override anywhere regarding the controls.
      Thanks!
