Static - Fix Controller for each Emulator
Hello,
when i map a N64 Controller and i play N64 it will work without any problems.
When i change to SNES (or another emulator) it not will take the right controller für SNES.When i write a config for each Emulator (retroarch.cfg for snes, n64, ms dos, ps1) it is not working too.
On what place i can write a command so the emulator always takes the same controller:
like Snes -> always take "SNES USB Controller #1" for Player 1 and "SNES USB Controller #2" für Player 2
the same one with "Mayflash USB N64 Adapter #1234" for Player 1-2-3-4!?
thanks for your help,
Simon
Did you try @meleu's joystick-selection tool?
