    Problem with burning RE2 on psx
    resident evil 2psx problemscd burn problem
    3 Posts 3 Posters 920 Views
      SonicPL95
      Hello, anyone knows why after i burn and play Resident Evil 2 dual shock ver. CD2 on my psx its works fine until i skip movie when gameplay should start but its just stops and show nothing more than black screen? anyway its work on emulators from rom and my burned cd's very well without problems but wont work correctly on my psx and psone, please someone knows what can be wrong? i try many versions from many sites and many burn programs but its just wont work, any way cd1 works fine the same as other games.
      • W
        Werker @SonicPL95
        Hi @SonicPL95 I just came across with exact the same problem!! I know it is an old post, but did you find a solution?
          reppyem
          Do u find solution guys?
