    Roms wont load onto retropi
    roms dont work
    4 Posts 3 Posters 495 Views
    • H
      Hans100
      my steps:
      1. plug blank usb into retropie
      2. retropie downloads bios, roms, and slashscreen files
      3. then i copied roms into right console folders
      4. then i put usb back into pie and waited for light to stop blinking
      5. then i rebooted retropie but none on the games were there just the retropie settings screen
        If anyone can help me with this issue i would greatly appreciate it.
        Is there another method to download roms?
        Have you checked the docs ?
        • H
          Hans100
          what do you mean by documents, which ones
          ByteThisB 1 Reply Last reply Reply Quote 0
          • ByteThisB
            ByteThis @Hans100
            @Hans100 He just gave you a link to your question about any other method to transfer roms..click on the link..it explains all you need. :-)
