Navigation
    • Search
    Coin and Player 1 buttons not working on PiCade console...
    Help and Support
    coin button p1 button picade console
    3
    6
    683
    • skilgannon1971
      skilgannon1971 last edited by
      Hi there, just built my new Picade Console and installed the latest version of retropi.
      I’m using Raspberry Pi 3b with it.
      Everything is working fine apart from the coin button (and player 1 button also). Both are “active” and can be seen as they both can be configured as a button in the config settings for Retropi but when using MAME it won’t “deposit a coin” so I can never actually start a game :(
      I’ve checked the connections on the HAT and everything seems ok…
      If I use a USB keyboard - I can use “6” to put in a coin but I need to use “1” to start player 1 game as the player one button doesn’t work at this point either
      Any ideas good folks?
      Cheers,
      John
      PS - I've posted this on PiMoroni too but as yet no help.
      mitu 1 Reply Last reply Reply Quote 0
      • mitu
        mitu Global Moderator @skilgannon1971 last edited by mitu
        @skilgannon1971 Which 'Mame' ? There are multiple arcade emulators in RetroPie - which one are you using ? If you configured your buttons through the Emulationstation's input mapping dialogue, the the Hotkey button you've chosen (or Select) is mapped to the 'coin insert' action.
        • skilgannon1971
          @mitu thanks, I'm using Mame4all. I did configure the buttons through emulation station. The hotkey button was configured to "escape" originally (side right button on the console) but I've since tried to map the hot key to the all "black buttons" (P1, Coin etc) in turn with no joy. Still no coin insert...
          Cheers
          John
          BuZz 1 Reply Last reply Reply Quote 0
          • BuZz
            BuZz administrators @skilgannon1971 last edited by BuZz
            @skilgannon1971 mame4all is not automatically configured in the same way as the libretro emulators. It's also a bad choice for a RPI3. I would use lr-mame2003 - check the arcade documentation for more info.
            https://retropie.org.uk/docs/Arcade/
            • skilgannon1971
              Thanks @BuZz I'll try that now.
              • skilgannon1971
                @BuZz SOLVED!!! Thank you so much - that worked!!! This also ties in with what @mitu said in respect of the "select" button being mapped to coin. YAY :)
