    Using MAME Overlays/Bezels and shaders with RetroArch in RetroPie
    124 Posts 29 Posters 138.6k Views
    • FloobF
      Floob
      This video shows how to add MAME overlays and shaders to your RetroPie setup.
      This is using RetroArch (I'm using lr-mame2003) so it wont work with pifba, gngeo, advmame etc..
      Before trying it, PLEASE make sure you understand how MAME works:
      https://github.com/RetroPie/RetroPie-Setup/wiki/Managing-ROMs
      Download Link:
      http://smartretro.co.uk/forums/viewtopic.php?f=3&t=8288
      R 1 Reply Last reply Reply Quote 2
        chavatar
        This is brilliant, thank you! Had great fun trying these out. Using the tool, After Burner II has a slight identity crisis with 1943?
        FloobF 1 Reply Last reply Reply Quote 0
        • N
          newbie Banned
          Cool, but I couldn't get this to work, I got all kinds of errors trying to install it. Is there something missing in this video?
          • FloobF
            Floob @chavatar
            @chavatar You're right!
            I've fixed it here, and will upload it later.
            To fix it yourself nano /home/pi/RetroPie/roms/mame-libretro/aburner2.zip.cfg
            and change the text 1943.cfg to aburner2.cfg
              bazola
              This is great! Thanks for your hard work ;)
              • E
                efraimsangil
                It's possible to use in Attract Mode ?
                • FloobF
                  Floob @efraimsangil
                  @efraimsangil Of course, its exactly the same, this is independent of front ends, it just relies on the RetroPie scripts and RetroArch.
                  E R 2 Replies Last reply Reply Quote 0
                  • FloobF
                    Floob @bazola
                    @bazola Thank-you :) Glad you like it.
                    • E
                      efraimsangil @Floob
                      @Floob said in Using MAME Overlays/Bezels and shaders with RetroArch in RetroPie:
                      Oh yes!
                      It is working perfectly, thank you very much.
                      How to get more bezels? :)
                      • Z
                        Zigurana
                        Cool!
                        How do these overlays work on a 4:3 display? Will it cut off the sides or try to stretch to fit?
                        EDIT: a you mention something about 1080p resolutions
                        , so I'm guessing it will be quite a bit of work to get this to work on meagre 1024x768 screen...
                        Then again, based on
                        , I would need to go into the configs that have explicit resolutions mentioned, and adjust those as well.
                        Maybe I'll try a batch crop/resize just to see how it ends up looking...
                        • FloobF
                          Floob @efraimsangil
                          @efraimsangil said in Using MAME Overlays/Bezels and shaders with RetroArch in RetroPie:
                          Oh yes!
                          You can create you own bezels, or maybe check the forum post over on
                          http://libretro.com/forums/showthread.php?t=5085
                          • FloobF
                            Floob @Zigurana
                            @Zigurana said in Using MAME Overlays/Bezels and shaders with RetroArch in RetroPie:
                            Cool!
                            Probably really badly, they are all 1920x1080, and even if they were resized some of the configs hardcode the res of the game, so probably not an ideal situation for non 1080p output. Worth a bash though, yes as you say you would need to change the configs. A crop would probably be easiest, but then you would probably lose some of the bezel art - although I guess a lot of them dont have much of importance at the extremities.
                              bengus
                              Floob: This is absolutely fantastic. Thank you for taking the time to add this to your video manager tool. It is greatly appreciated!
                              • FloobF
                                Floob @bengus
                                @bengus No problem. Thanks for the comment, I'm glad its useful.
                                  dabone
                                  Does anyone have a source for overlays without the flare and scratches on the main screen area?
                                  I used to collect real arcade games, and if my games had looked that bad, they would have gotten new glass.
                                  Most of these look like scratched up plexiglass with a light right above you.
                                  Other than that I love this feature.
                                  Later,
                                  dabone
                                  • FloobF
                                    Floob
                                    Lots here:
                                    http://mrdo.mameworld.info/mame_artwork_ingame.php
                                      punking
                                      Hi
                                      Thanks for the effort and time in producing the video manager tool. It works great. I have one question.
                                      For Mame2003 roms that don't have any overlays or shaders pre-made how do I configure a cfg file to at least smooth the screen, scanlines and maybe even the curvature.
                                      For example:
                                      When I run Hyper Sports now it looks terrible because there's no smoothing or any effect applied. It's blocky and sharp.
                                      Would I have to create a cfg for that specific rom and what would I have to put into it.
                                      Thanks for your time.
                                      • FloobF
                                        Floob @punking
                                        @punking said in Using MAME Overlays/Bezels and shaders with RetroArch in RetroPie:
                                        Hi
                                        No problem.
                                        You could enable a shader for the system as a whole using the configuration manager
                                        https://github.com/retropie/retropie-setup/wiki/Configuration-Editor
                                        This would effectively edit /opt/retropie/configs/mame-libretro/retroarch.cfg
                                        For example:
                                        Yeah, thats the "natural" look - I dont like it either :) Although to be fair typically the resolution would be tweaked.
                                        You can either create a .cfg for that rom, which could include resolution settings, or you can set a system (lr-mame2003) wide settings such as integer scaling and a shader enabled.
                                          punking
                                          Thanks for the quick reply. That all worked.
                                          • H
                                            Higgy
                                            First off as others have said great work Floob.
                                            I am using a PC Monitor (via DVI connection) like I imagine a lot of others must be. Mine has the typical widescreen resolution of 1440x900 (it probably also does 1280x800) so a 16:10 ratio.
                                            I was going to have a bash at just converting one of your files/cfg for 1440x900, I had selected Donkey Kong first.
                                            I got it all working last night, it looks great!!
                                            Before I crack on and convert the others, I have a question:
                                            DKong has a native res of 224 x 256 but RetroArch is displaying it in a 750 x 1000 window. This is not a multiple of the original, so this does not matter? - Does the RPi hardware do all this without much performance punishment?
                                            Scaling your numbers into my 1440x900 I have now the following in the .zip.cfg file:
                                            custom_viewport_width = "750" Custom_viewport_width = "625"
                                            custom_viewport_height = "1000" custom_viewport_height = "833"
                                            custom_viewport_x = "585" custom_viewport_x = "408"
                                            custom_viewport_y = "50" custom_viewport_y = "42"
                                            I am trying to keep the aspect ratio of you Overlay Window correct. So my width/height is just reduced by a factor of 1.2
                                            The start location in x is slightly different as it is initially scaled to 1600 to keep the correct scaling and then cropped to 1440 so I have to scale by 1.2 then subtract 80 pixels [ (1600-1440) / 2]
                                            Is there a fancy way of reading in the parameters for each *.zip.cfg file and performing a maths function then re-writing out the file? It will save me a lot of time :)
                                            I have converted all the Overlay .PNG's using a batch conversion with GIMP to 1440x900
                                            cheers
