    Emulationstation internal scraper problems [Updated]
    emulationstatioscraperthegamesdb
    8 Posts 6 Posters 17.8k Views
      Emulationstation's internal scraper - which uses thegamesdb site - is not working at the moment.
      The scraping site has shutdown the legacy API (3 Jan 2018) used by Emulationstation, so scraping is not going to work with the current version.
      While a solution is found, you can use the other scrapers included in the RetroPie installation - Lars Muldjord's Skyscraper or Steven Selph's scraper - to scrape your games.
      Update: Feb 2019 13
      A new Emulationstation version has been released, featuring an updated scraper - including support for both TheGamesDB (gratiously contributed by @acrummyidea) and ScreenScraper sites. The new version, which includes the updates, is currently 2.8.x and features also other fixes and additions.
      You can update to this version using the normal RetroPie-Setup update process.
      If you're still running Raspbian Jessie (from a RetroPie image older than 4.4), then you'll have to install from source the new version. Due to a missing dependency, you'll have to manually install the rapidjson-dev package from Debian Backports before attempting to update from source.
      wget http://ftp.us.debian.org/debian/pool/main/r/rapidjson/rapidjson-dev_1.1.0+dfsg2-3~bpo9+1_all.deb
      sudo dpkg -i rapidjson-dev_1.1.0+dfsg2-3~bpo9+1_all.deb
      1 Reply Last reply Reply Quote 7
        che_don_john
        This post is deleted!
        mituM rogg23R 2 Replies Last reply Reply Quote 0
          mitu Global Moderator @che_don_john
          • rogg23R
            rogg23 @che_don_john
              che_don_john @mitu
              • zefolhadelaZ
                zefolhadela
                hope you guys get this work man ;) do you know if i can scrap rom individualy with those methods? or maybe will overwrite those roms that i already scraped manually?
                • F
                  Failrunner
                  I can't scrape with any method. One of the scrapers deleted my metadata and images. 😭😭😭
                    BuZz administrators @Failrunner
                    @Failrunner open a new topic for help and include information about your set-up.
