    dos box"directory doesn't exist"
    retropiedosboxraspberry pi 3
    26 Posts 4 Posters 9.9k Views
      brunin
      hello i have seen more tutorials and i can't find an an answer (i am french)
      i can't mount drive or directory in dosbox because when i type: [mount c c:/"name of directory"] dosbox let me see "directory doesn't exist"
      help me please
      +my letter drive deffault when i oppen dosbox in retropi on my raspberry pi3 is c: ans i can go in z:
      • quicksilverQ
        quicksilver @brunin
        @brunin pc is already mounted as c:
        Try:
        cd tilt
        Then run your game from that folder. Also I believe it is case sensitive.
          brunin
          i have to mount the forlder beecause the game have to run whith the cd
          • quicksilverQ
            quicksilver @brunin
            @brunin Then you need to use the imgmount command to mount it as a "disc". Needs to be an .iso or .bin/cue
            Also you'll need to use a different letter since C is already mounted as your hard drive. Try something like this:
            imgmount d "/home/pi/RetroPie/roms/pc/nameofgame.iso" -t iso just make sure to point it where ever your .iso file actually is.
              brunin
              not an iso it's a folder and i can't mount just a drive anywhere
                mitu Global Moderator @brunin
                @brunin mount can mount a folder as a CD ROM, but the game might have some copy protection which expects the actual CD. If you wish to mount the folder as a CD-Drive, try something like
                mount d "/home/pi/RetroPie/roms/pc/tilt" -t  cdrom
                  brunin
                    brunin @mitu
                    • quicksilverQ
                      quicksilver @brunin
                      @brunin it's case sensitive I'm pretty sure. Needs to be TILT based on the prior picture your posted
                        brunin @quicksilver
                        @quicksilver can you explain more clear please i'm french and i try to translate it's difficult
                          BuZz administrators @brunin
                          @brunin the folder is RetroPie not retropie. Also check the case of the tilt folder.
                            brunin
                            i had trying this (view image)
                            the rirectory of rom is placed in roms/pc
                              @brunin why are you putting c:/back in there? - just use /home/pi .. (and don't forget -t cdrom)
                                brunin
                                i am disapointed
                                  @brunin the tilt folder may be lowercase. Check not from dosbox but from however you uploaded the data (eg samba share)
                                    brunin @BuZz
                                    @BuZz i just want to play the game"tilt"(it's a pinball game)
                                    i have seen i can place the directory decompressed in pc rom games
                                    so:
                                    and i have installed the game by typing on dosbox "c:\tilt>install.exe"
                                    the install create the folder TILT in "pc/tilt
                                      brunin
                                      when i want to play game by tiyping "pinball.exe" in directory ...roms/pc/tilt dosbox shows "intall first"
                                      it's beecause i think i have to mount Something but..........?
                                        How would you normally play the game - in DOS/Windows ? What would you execute - TILT.BAT, TILT.EXE or Pinball.exe ?
                                          brunin
                                          you're answer not help me
                                          BuZzB quicksilverQ 2 Replies Last reply Reply Quote -1
                                            @brunin you won't get help like that.
                                            The folder name is lowercase btw. It's tilt not TILT. This can be clearly seen in the location bar on the screenshot.
