    Bezel Project Problems with Snes
    retropiebezel-projectsuper nintendoraspberrypi 3b+problem
    9 Posts 3 Posters 2.7k Views
    • V
      VeilCrow
      Hello, I'm extremely green in raspberry pi/ retropie mod ding and emulation but I've learned a lot in such a short time. Excuse me if this issue has been discussed before but I'm havino trouble finding anything related to my issue on here or anywhere else.
      I've installed and implemented the bezel project and it works for all my supported systems except the snes. Well, technically it works, but I'm only getting a generic snes bezel for all my games. It doesn't seem to be a naming conflict or anything as it works with my genesis system just fine and I get my games from the same place. I was wondering if it was a known issue or just some simple mistake.
      Cliff notes ver.
      Bezel project works for my other systems in retropie. Snes only shows generic snes bezel across all games.
      Running latest versions of retropie and bezel project on 3 b plus.
      I apologise for any newbie errors as I'm still new to this and forum diction/conduction.
      Thanks.
        @VeilCrow said in Bezel Project Problems with Snes:
        The Bezel project is not distributed by RetroPie, so I can't say if it's just a mistake or a known issue.
        What emulator are you using ? I see the Bezel project provides configurations for the snes9x and snes9x 2010 emulators .
        Is this the overlay/bezel you're seeing ?
        • V
          VeilCrow @mitu
          @mitu Thanks for replying. I'm using whatever is default in retropie for emulation. And yes that is the bezel I see when playing.
            mitu Global Moderator @VeilCrow
            Well, check if you're using one of the supported emulators by the Bezel project. When starting a SNES game, press a button when the Runcommand launch menu is shown and check which is the emulator used for the system (SNES).
            • V
              VeilCrow @mitu
              @mitu I've figured it out. It was naming conflicts. I feel dumb. You're input is much appreciated and sorry for slow replies.
              But now that I've fixed the problem for snes and the rest of my psx roms it seems I've opened another can of worms. When I rescraped with sselph scraper it duplicated some of my games. It's really soaked up my weekend and my patience lol. But I'll figure it out.
              mituM UberLumbyU 2 Replies Last reply Reply Quote 0
                @VeilCrow It's probably because it counted your .bin files as ROMs , along with the corresponding .cue files. I can't find an option in the parameters to skip some extensions, so my advice would be to move out the .bin files into a separate folder, then scrape only the .cue files.
                • V
                  VeilCrow @mitu
                  @mitu Yeah I figured it might be that. Strange thing is its only some of my psx roms. Others are fine. But I'll definitely try you suggestion.
                  Thanks for all the help. I must say the retropie bug bit me hard and I'm loving every minute of it. Even the frustrating parts lol.
                  • UberLumbyU
                    UberLumby @VeilCrow
                    @VeilCrow I'm having this issue right now what do you mean by naming conflicts? Did you need to get new roms? When I use the bezel project on SNES and SFC most of the SFC games have a blank bezel but it shows on display it has the correct name of the .cfg for the bezel but doesn't show up. As for SNES it's mostly the default bezel but some random games get the custom bezel. If anyone can help please lmk ty
                    [Linux 5.10.103-v7+ armv7l GNU/Linux
                    Retropie 4.8
                    Raspberry Pi 3B+]
                    UberLumbyU 1 Reply Last reply Reply Quote 0
                    • UberLumbyU
                      UberLumby @UberLumby
                      I know this is an old post but it's the only one I can find that has a similar issue especially with SNES. I'm assuming it has to do with I have donkey Kong rev a and the the image for the bezel doesn't have that name
                      )Raspbian 5.4.51c71 armv71
                      Raspberry pi 4 4GB model
                      Retropie 4.6.7
                      Retroarch 1.8.8
                      Snes9x2010
                      Retropie 4.8
                      Raspberry Pi 3B+]
