    Is there a way to change the "Front" system when Retropie starts?
    retropie 4.0.2
    3 Posts 3 Posters 512 Views
      tomjohn77
      I've already edited es_systems.cfg to re-order my consoles around. It automatically starts at the front of that list when Retropie starts, with the config option to the left and and following consoles to the right. Any way to make it so that it starts in the [middle](link url), with consoles on the left AND right, with the config option all the way around either side? new movies on netflix 123 movies
      movies
      Mine did this BEFORE I manually edited it, as I added ROMS bit by bit. But no idea how to force it.
      simpleethatS 1 Reply Last reply Reply Quote 0
        Clyde
        There is the option Main Menu > UI Settings > Start On System in Emulation Station's GUI, but I don't know if it does work with a rearranged es_systems.cfg.
        • simpleethatS
          simpleethat @tomjohn77
          @tomjohn77 If that suggestion doesn't work just reorder the manually edited es_systems.cfg so that the the system you want to start on is at the top and the system you want to be left of the starting system is on the right then put the Retropie menu "system" in the middle of es_systems.cfg
