    OT: Am I a weirdo or still normal? :-D
    configconfigurationplaygames
    28 Posts 8 Posters 5.0k Views
      Clyde @quicksilver
      @quicksilver Same here, that's one thing I like in arcade games. They are meant to be played for a short time, whereas many console and computer games tend to demand more of your time. I mostly play 10-20 minutes after I come home from work, when I have to leave soon, or when I wait for guests to arrive.
      when I finally get to a place where everything is working smoothly, instead of sitting and playing the games I start to look for more things to tinker with.
      This! Absolutely! 😃
      That said, guys and gals, be sure to make backups on a regular basis, lest you may lose all of your hard work in one fatal moment. ⚠️
      TimZettT 1 Reply Last reply Reply Quote 0
      • TimZettT
        TimZett @Clyde
        @Clyde said in OT: Am I a weirdo or still normal? :-D:
        ...especially when your flash memory (SD card or USB) shows first signs of dying :-)
        In my case, fortunately everything still worked including file system access, so I was able to backup things on file level.
        I know a similar share of women from a gaming-themed bar called interFace here in Berlin, Germany
        Looks really nice. Let's see, I might come to Berlin in autumn. If so I will give it a shot ;-)
          Clyde @TimZett
          @TimZett said in OT: Am I a weirdo or still normal? :-D:
          If you do, let me know and we could have a drink, maybe in the interFace bar. (Only if you want to, of course. No problem if you don't. 😉 )
          TimZettT 2 Replies Last reply Reply Quote 0
          • TimZettT
            TimZett @Clyde
            This post is deleted!
            • TimZettT
              TimZett @Clyde
              Sure, why not :-)
              • CapemanC
                Capeman
                I have 3 pi setups. A bartop arcade, a modded atari that hdmi’s out to a flatscreen tv and a pi built into a CRT. I can finally say after messing with Retropie for 5 years now, I’m finally at a place where all my setups are basically complete except for the occasional adding or deleting of a romhack or 2.
                I play a lot now, and would you guess I use my CRT setup the most? It’s just the most authentic and the least lag. CRTs are the best.
                m2306M 1 Reply Last reply Reply Quote 0
                • m2306M
                  m2306 @Capeman
                  @Capeman I haven’t even seen an actual CRT in a very long time. I just tried one of the Retroarch default CRT shaders for the first time and it looks great and with no apparent lag on Famicom emulation. It definietly adds to the feeling so I see what you mean, it would probably be even cooler on real CRT. Thuogh for me a real CRT is out of the question due to size and weight.
                  BobHarrisB 1 Reply Last reply Reply Quote 0
                  • BobHarrisB
                    BobHarris @m2306
                    @m2306 Lag really doesn't have to be an issue, but it can be with the wrong hdtv. On mine I can't notice any input lag. Maybe I would be able to notice it if I could play the game side by side, crt tv vs hdtv, but it's all good for me the way I've got it set up right now.
                    Pi 3B , 64 GB Sandisk ultra flashdrive, 19 systems, 872 hand picked classic gaming gems :-) Dual shock 4v2
