    universal xml scrapper problems
    universal xml
    8 Posts 2 Posters 532 Views
      sleepdaddy
      hey!
      just downloaded some images for some of my retropie games, but unfortunately they won't show up in game selection for some reason.
      https://imgur.com/a/J8NVoIB
      he also created a new folder "config" on my USB drive https://imgur.com/a/pK0R8sO
      gamelist seems fine too: https://imgur.com/a/sVXP15o
      maybe there's some folder / path issues where he can't find images?
        mitu Global Moderator @sleepdaddy
        @sleepdaddy The configs folder would never be on the USB stick if you use the automatic method of running the ROMs from the USB folder. You should try and point UXS to the config file share on the PI (\\retropie\configs).
        You can manually copy the downloaded images folder (n64) to the \\retropie\configs\all\emulationstation\downloaded_images folder and also the gamelist.xml to the corresponding location (\\retropie\configs\all\emulationstation\gamelists\n64), then restart Emulationstation and see if anything comes up.
        If that doesn't work, try re-scraping again with the right config folder location (i.e. not on the USB stick).
          sleepdaddy @mitu
          @mitu said in universal xml scrapper problems:
          Thanks will try out asap!
            sleepdaddy
            So I have changed everything now and set up the raspberry pi via network (SSH), which was the better choice for sure. But the problem is now, when I try to connect the scraper to my Raspberry pi instead of my USB device, I get the following error message:
            Everything is working fine through my network. What could it be?
              @sleepdaddy Check the logs folder, there may be some indication there.Did you changed the password on the for the pi user ? Don't have a Windows system right now to check, sorry.
                sleepdaddy
                Hm, I don't think so. Password is still pi:raspberry as usual. I also tried direct IP instead of RETROPIE as host. Connecting via Putty or WINscp is working fine so far.
                Checked the log.txt. That's what it's saying:
                [17:39:59] - D:\Downloads\Universal_XML_Scraper64.exe (2.2.0.3)
                [17:39:59] - WIN_10(X64) - 0407
                [17:39:59] - Scrape in x64
                [17:39:59] - > No updated files needed (Version : 2.2.0.3)
                [17:39:59] - Starting files installation
                [17:39:59] - > Ending files installation
                [17:40:00] - > File Downloaded Path : D:\Downloads\Ressources\ServerList.txt
                [17:40:00] - > -In 1 try and 0.26s
                [17:40:00] - > Server (fallback) = https://www.screenscraper.fr/
                [17:40:00] - > Verbose LVL : 2
                [17:40:00] - > Path to ini : D:\Downloads\UXS-config.ini
                [17:40:00] - > Path to log : D:\Downloads\LOGs\log.txt
                [17:40:00] - > Path to language : D:\Downloads\LanguageFiles
                [17:40:00] - Language Selected : 0409
                [17:40:00] - > Update Checking
                [17:40:00] - > File Downloaded Path : D:\Downloads\changelog.txt
                [17:40:00] - Local : 2.2.0.3 - Github : 2.2.0.3
                [17:40:01] - > File Downloaded Path : D:\Downloads\Ressources\systemlist.xml
                [17:40:01] - > -In 1 try and 0.51s
                [17:40:01] - > systemlist.xml Opened
                [17:40:01] - > File Downloaded Path : D:\Downloads\Ressources\Countrylist.xml
                [17:40:01] - > -In 1 try and 0.26s
                [17:40:01] - > Countrylist.xml Opened
                [17:40:02] - > File Downloaded Path : D:\Downloads\Ressources\Genresliste.xml
                [17:40:02] - > -In 1 try and 0.26s
                [17:40:02] - > Genrelist.xml Opened
                [17:40:02] - Setting Mix Template
                [17:40:02] - > 7za command: "D:\Downloads\Ressources\7za.exe" x "D:\Downloads\Mix\Standard (3img).zip" -o"D:\Downloads\Mix\TEMP" -aoa
                [17:40:02] - Unziped : D:\Downloads\Mix\Standard (3img).zip to D:\Downloads\Mix\TEMP
                [17:40:06] - /!\ Error Access to :
                [17:40:06] - > _XML_UpdateField (Profil/General/Mix) = True
                [17:40:06] - > _XML_UpdateField (Profil/General/Target_Image_Extension) = png
                [17:40:06] - > _XML_UpdateField (Profil/Element[@Type="Picture"]/Source_Download_Ext) = png
                [17:40:06] - > _XML_UpdateField (Profil/Element[@Type="Picture Alt"]/Source_Download_Ext) = png
                [17:40:06] - No system found for :
                [17:40:06] - > SSH Enable
                [17:40:06] - > GUI Refresh
                [17:40:06] - > GUI Constructed
                [17:40:30] - > _XML_UpdateField (Profil/Plink/Ip) = RetroPie
                [17:40:30] - > _XML_UpdateField (Profil/Plink/Root) = pi
                [17:40:30] - > _XML_UpdateField (Profil/Plink/Pswd) = raspberry
                [17:40:30] - SSH Parameter Saved
                [17:40:30] - > ------------------------
                [17:40:30] - > Host = RetroPie
                [17:40:30] - > Login = pi
                [17:40:30] - > Password = raspberry
                [17:40:30] - > _XML_UpdateField (Profil/General/Mix) = True
                [17:40:30] - > _XML_UpdateField (Profil/General/Target_Image_Extension) = png
                [17:40:30] - > _XML_UpdateField (Profil/Element[@Type="Picture"]/Source_Download_Ext) = png
                [17:40:30] - > _XML_UpdateField (Profil/Element[@Type="Picture Alt"]/Source_Download_Ext) = png
                [17:40:30] - No system found for :
                [17:40:30] - > SSH Enable
                [17:40:30] - > GUI Refresh
                [17:40:41] - SSH Parameter Canceled
                [17:40:41] - > _XML_UpdateField (Profil/General/Mix) = True
                [17:40:41] - > _XML_UpdateField (Profil/General/Target_Image_Extension) = png
                [17:40:41] - > _XML_UpdateField (Profil/Element[@Type="Picture"]/Source_Download_Ext) = png
                [17:40:41] - > _XML_UpdateField (Profil/Element[@Type="Picture Alt"]/Source_Download_Ext) = png
                [17:40:41] - No system found for :
                [17:40:41] - > SSH Enable
                [17:40:41] - > GUI Refresh
                [17:40:52] - > _XML_UpdateField (Profil/Plink/Ip) = RETROPIE
                [17:40:52] - > _XML_UpdateField (Profil/Plink/Root) = pi
                [17:40:52] - > _XML_UpdateField (Profil/Plink/Pswd) = raspberry
                [17:40:52] - SSH Parameter Saved
                [17:40:52] - > ------------------------
                [17:40:52] - > Host = RETROPIE
                [17:40:52] - > Login = pi
                [17:40:52] - > Password = raspberry
                [17:40:52] - > _XML_UpdateField (Profil/General/Mix) = True
                [17:40:52] - > _XML_UpdateField (Profil/General/Target_Image_Extension) = png
                [17:40:52] - > _XML_UpdateField (Profil/Element[@Type="Picture"]/Source_Download_Ext) = png
                [17:40:52] - > _XML_UpdateField (Profil/Element[@Type="Picture Alt"]/Source_Download_Ext) = png
                [17:40:53] - No system found for :
                [17:40:53] - > SSH Enable
                [17:40:53] - > GUI Refresh
                [17:42:48] - > _XML_UpdateField (Profil/Plink/Ip) = 192.168.178.31
                [17:42:48] - > _XML_UpdateField (Profil/Plink/Root) = pi
                [17:42:48] - > _XML_UpdateField (Profil/Plink/Pswd) = raspberry
                [17:42:48] - SSH Parameter Saved
                [17:42:48] - > ------------------------
                [17:42:48] - > Host = 192.168.178.31
                [17:42:48] - > Login = pi
                [17:42:48] - > Password = raspberry
                [17:42:48] - > _XML_UpdateField (Profil/General/Mix) = True
                [17:42:48] - > _XML_UpdateField (Profil/General/Target_Image_Extension) = png
                [17:42:48] - > _XML_UpdateField (Profil/Element[@Type="Picture"]/Source_Download_Ext) = png
                [17:42:48] - > _XML_UpdateField (Profil/Element[@Type="Picture Alt"]/Source_Download_Ext) = png
                [17:42:48] - No system found for :
                [17:42:48] - > SSH Enable
                [17:42:48] - > GUI Refresh
                [17:42:50] - Wizard - Profil selected : D:\Downloads\ProfilsFiles\Retropie.xml
                [17:42:51] - > _XML_UpdateField (Profil/General/Mix) = True
                [17:42:51] - > _XML_UpdateField (Profil/General/Target_Image_Extension) = png
                [17:42:51] - > _XML_UpdateField (Profil/Element[@Type="Picture"]/Source_Type) = MIX_Template
                [17:42:51] - > _XML_UpdateField (Profil/Element[@Type="Picture"]/Source_Download_Ext) = png
                [17:42:51] - > _XML_UpdateField (Profil/Element[@Type="Picture Alt"]/Source_Download_Ext) = png
                [17:42:51] - Wizard - Media selected : MIX
                [17:42:51] - > 7za command: "D:\Downloads\Ressources\7za.exe" x "D:\Downloads\Mix\Standard (3img).zip" -o"D:\Downloads\Mix\TEMP" -aoa
                [17:42:51] - Unziped : D:\Downloads\Mix\Standard (3img).zip to D:\Downloads\Mix\TEMP
                [17:42:53] - MIX Configuration Saved : Standard (3img)
                [17:42:53] - Wizard - Mix selected : Standard (3img)
                  @sleepdaddy said in universal xml scrapper problems:
                  So the connection is not a problem, seems like it doesn't know which system it should scrape.
                    sleepdaddy
                    Huh, how do I tell him? Could not find anything related :/
