Problem with ps1 game
im trying to run Medievil II (thanks to the nostalgia knowing a remake its about to hit the market) it starts and function perfectly, but the soundtrack always gets messed up, for example each time i go trough a door it randomly changes the music to the music of another lever, i assume is something related to lybcript, but the pal and the ntsc give me the same problem, i tried everything i know, any ideas how to fix it? i
using raspberry pi 3b+ in a nespi case + and retropie 4.4. and lr-pcsx-rearmed -
@Bryam_h_m make sure you have the psx bios installed. if you do, it may just be a bug in the emulator, which may have no fix.
