    lr-mupen64plus-next: experimental scriptmodule for testing
    retroarchlibretro coreexperimentaltestingn64
    80 Posts 13 Posters 19.9k Views
    • hooperreH
      hooperre @sdtom
      @sdtom An issue is opened with lr-mupen64plus-next on GitHub. Happens across different platforms. It seems like it has garnered their immediate attention. May want to update from source, as they have it marked as internally hotfixed.
      Follow it here: https://github.com/libretro/mupen64plus-libretro-nx/issues/49.
      4B ~ RPi PSU 5.1V / 3.0A ~ 32GB SanDisk microSD ~ 128GB USB
      • retropieuser555R
        retropieuser555
        Hi all when trying to install this it gives me an error in the logs. I'm not quite sure what I'm looking for but here is the log file's detail below:-
        Log started at: Sun 22 Mar 17:53:36 GMT 2020
        RetroPie-Setup version: 4.5.1 (f90600a2)
        System: Raspbian GNU/Linux 9.9 (stretch) - Linux retropie 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l GNU/Linux
        Installing dependencies for 'lr-mupen64plus-next' : N64 emulator - Mupen64Plus + GLideN64 for libretro (next version)
        /home/pi/RetroPie-Setup/tmp/build/lr-mupen64plus-next /home/pi
        Getting sources for 'lr-mupen64plus-next' : N64 emulator - Mupen64Plus + GLideN64 for libretro (next version)
        git clone --recursive --depth 1 --branch GLideN64 "https://github.com/libretro/mupen64plus-libretro-nx.git" "/home/pi/RetroPie-Setup/tmp/build/lr-mupen64plus-next"
        Cloning into '/home/pi/RetroPie-Setup/tmp/build/lr-mupen64plus-next'...
        warning: Could not find remote branch GLideN64 to clone.
        fatal: Remote branch GLideN64 not found in upstream origin
        fatal: Cannot change to '/home/pi/RetroPie-Setup/tmp/build/lr-mupen64plus-next': No such file or directory
        HEAD is now in branch '' at commit ''
        /home/pi
        Error running 'git clone --recursive --depth 1 --branch GLideN64 https://github.com/libretro/mupen64plus-libretro-nx.git /home/pi/RetroPie-Setup/tmp/build/lr-mupen64plus-next' - returned 128
        Log ended at: Sun 22 Mar 17:53:38 GMT 2020
        Total running time: 0 hours, 0 mins, 2 secs
        Any ideas? Or is this happening with anyone else?
        Pi 5 4GB
          BuZz administrators @retropieuser555
          @retropieuser555 your RetroPie-Setup is not up to date. Please also open a new topic for issues.
          retropieuser555R 1 Reply Last reply Reply Quote 1
          • retropieuser555R
            retropieuser555 @BuZz
            @BuZz Thanks for the reply. 4.5.1 isn't the most recent RetroPie? I was reluctant to do an update as whenever I do it always seems to take hours. Anyway, I'll give that a go on my pi this evening anyway as I guess that'll fix. If it doesn't I'll make a new topic.
            Pi 5 4GB
            • quicksilverQ
              quicksilver @retropieuser555
              @retropieuser555 just update retropie-setup script then update lr-mupen64plus-next. You don't need to update all packages.
              • retropieuser555R
                retropieuser555
                Thanks guys! That worked perfectly and got a fair number of games running as smoothly as I did previously with the previous mupen64.
                Btw one thing I did notice is the AKI wrestling games (World Tour, WCW Revenge, Wrestlemania 2000, No Mercy, VPW2) all don't seem to work. But they do on the original lr-mupen64plus when using Glide64.
                With lr-mupen64plus-next, the display squashes into the top left corner of the screen and you get a couple of other graphical glitches. Has anyone else tested these games and been able to replicate this?
                Pi 5 4GB
                • quicksilverQ
                  @retropieuser555 which pi are you using?
                  • retropieuser555R
                    retropieuser555 @quicksilver
                    @quicksilver 3b+. I can get the games working great on the older mupen64 emulators. But when you set it to something other than Glide64, you get the game playing but no video display (you can tell the game is playing as you can press start, select items off the menu etc). So I wondered if it's something to do with needing to be that plugin?
                    Pi 5 4GB
                    • quicksilverQ
                      @retropieuser555 I can't replicate your issues. Can you open a new help topic with an overview of your setup?
                      • H
                        hhromic
                        Hello all, a quick PSA :)
                        The lr-mupen64plus-next core got updated some days ago and now is defaulting to 640x480 resolution for new installs. This resolution is a bit taxing for humble devices such as the RPI3 or less, so is strongly recommended that you set the rendering resolution to 320x240 (as it was previously the default) for these devices. Perhaps this is not necessary for RPI4, you have to see for yourself.
                        This can be done after starting any game and going to the core options menu in RetroArch.
                        It is important to note that this is not a RetroPie change, but an upstream change. We decided to not change the upstream defaults therefore it is your responsability to change this setting for your own setup.
                        If you had the core previously installed, the new defaults will not apply because you already have the previous resolution set in your core options.
