    Strange scraping problem
    6 Posts 3 Posters 1.6k Views
      Cole_48
      When I scrape all of my games they all work and I can scroll though and see all the images but when I turned Retropie off and on again all the images and info was gone for all of my emulators except MS DOS and Ports. Am I doing something wrong? I am using Retropie 3.7
        Cole_48
        So is there an answer?
          Cole_48
          Sorry to be that person but bump
          • FloobF
            Floob
            Which scraper are you using?
            Please read this first to help us help you:
            • simonsterS
              simonster
              Are you shutting down RetroPie properly (from the START menu) or are you turning the power off without shutting down?
              If you pull the power, none of the Emulation Station gamelist files get saved. Also, if you pull the power, there is a chance that the filesystem will be corrupted.
                Cole_48
                Yes I am, that is why the MS DOS ones are saving
