    Problems building Dolphin on macOS Mojave - HELP ?
    install error
    13 Posts 6 Posters 1.7k Views
      azoreseuropa
      Hello.. I compiled other emulators for macOS and don't have a problem. I am not a noob but I have a problem. This is the first time I have a problem with Dolphin on macOS.
      -- Could NOT find OpenSLES (missing: OPENSLES_LIBRARY OPENSLES_INCLUDE_DIR)
      -- Could NOT find ALSA (missing: ALSA_LIBRARY ALSA_INCLUDE_DIR)
      -- ALSA NOT found, disabling ALSA sound backend
      -- PulseAudio NOT found, disabling PulseAudio sound backend
      CMake Error at Source/Core/DolphinQt/CMakeLists.txt:1 (find_package):
        By not providing "FindQt5.cmake" in CMAKE_MODULE_PATH this project has
        asked CMake to find a package configuration file provided by "Qt5", but
        CMake did not find one.
        Could not find a package configuration file provided by "Qt5" (requested
        version 5.9) with any of the following names:
          Qt5Config.cmake
          qt5-config.cmake
        Add the installation prefix of "Qt5" to CMAKE_PREFIX_PATH or set "Qt5_DIR"
        to a directory containing one of the above files.  If "Qt5" provides a
        separate development package or SDK, be sure it has been installed.
      -- Configuring incomplete, errors occurred!
      See also "/Users/azoreseuropa/dolphin-emu/build/CMakeFiles/CMakeOutput.log".
      See also "/Users/azoreseuropa/dolphin-emu/build/CMakeFiles/CMakeError.log".
      azoress-MacBook-Pro:build azoreseuropa$ make VERBOSE=1
      make: *** No targets specified and no makefile found.  Stop.
      According to this:
      macOS Build Steps:
      git clone https://github.com/dolphin-emu/dolphin.git
      cd dolphin
      mkdir build
      cd build
      When I type cmake .. and it was in processing then I got an error as above.
      Is something missing for cmake .. ?
      No, I have everything:
      pkg-config (brew install pkgconfig)
      SDL2 (brew install sdl2, or download this dmg)
      Qt5 (brew install qt5)
      CMake (brew install cmake)
      Help ? Thank you kindly.
      • herb_fargusH
        herb_fargus administrators
        I'm not aware of any retropie builds for macs
          azoreseuropa
          Ok, thanks @herb_fargus
          Anybody else ? Please ?
          • quicksilverQ
            quicksilver @azoreseuropa
            @azoreseuropa I think what herb fargus is saying is that this is a retropie forum. Since retropie is not available for Mac os then you might be asking your question in the wrong place.
              azoreseuropa
              Oh. Which one is the right place ? Sorry about that.
              • quicksilverQ
                @azoreseuropa https://forums.dolphin-emu.org/
                Here perhaps?
                  azoreseuropa
                  Already did. They are not being helpful. :(
                    backstander
                    I don't own anything running macOS so I don't know how much help this will be but...
                    It looks like it's having trouble finding your Qt5 source location.
                    You might need to add the location to the Qt bin/lib to the PATH environment variables:
                    https://github.com/dolphin-emu/dolphin/wiki/Building-With-Qt
                      azoreseuropa
                      Dont seems to be helped. :(
                        Charononus
                        I don't think there is a Retropie build for Mac, I sure haven't found one. But you could always do
                        brew cask install dolphin
                          azoreseuropa @Charononus
                          @Charononus said in Problems building Dolphin on macOS Mojave - HELP ?:
                          brew cask install dolphin ? Meaning ?
                            mitu Global Moderator @azoreseuropa
                            @azoreseuropa http://caskroom.io
                            ~> brew cask info dolphin
                            dolphin: 5.0
                            https://dolphin-emu.org/
                            Not installed
                            From: https://github.com/Homebrew/homebrew-cask/blob/master/Casks/dolphin.rb
                            ==> Name
                            Dolphin
                            ==> Artifacts
                            Dolphin.app (App)
                              azoreseuropa @mitu
                              @mitu said in Problems building Dolphin on macOS Mojave - HELP ?:
                              Oh yes.. I know that one. No, I don't want to install dolphin-5.0.dmg, lol. I want to compile it to the latest one. They will release 6.0 or so but I want to do it, you know. :)
