    [MOD] Retroflag MEGAPi Case - Built in XBOX 360 Wireless receiver
    retroflagmegapimoddingxbox 360receiver
    1 Posts 1 Posters 1.1k Views
      Anthrax
      Re: Sega Megadrive case from RetroFlag!
      Hi Everybody,
      just gotten around to play with RetroPie again and it still is by far the most versatile of all the distros I tried (Recalbox, Lakka, Batocera, Kodi Leia Retroplayer)!
      So a big thank you to this community is in Order: Thank You!
      Anyways just wanted to let the modders know that the MEGAPi Case just screams for adding a XBOX 360 wireless receiver... The second I took it out of the package I had to crack open my cheap China receiver and put it inside the top lid - and what can I say, it's a perfect fit!
      See for yourself...
      This should be pretty self explanatory so here is just the gist of it:
      • open receiver
      • cut the cord
      • (might require to) cut off the usb plug housing
      • drill a hole through the compartement under the top lid
      • resolder the usb cable
      • glue the receiver pcb where it fit's and the lid closes completely
      • connect the usb plug
      • close the lid
      • enjoy!!!
      best regards
      Anthrax
      PS: took 10mins (excluding the fight with the usb plug housing ;-)) beat my time!
