    Emulationstation theme give me gray box's...
    emultionstationtheme
    18 Posts 4 Posters 550 Views
    • shavecatS
      shavecat
      if i move too fast from rom to rom or console to console all the images go GRAY,
      if i play something and quit it fix but come back again...(using BLURAY theme)
      what can i do ?
        mitu Global Moderator @shavecat
        @shavecat Did you fix your VRAM settings ? What's your VRAM limit in Emulationstation ?
        • shavecatS
          shavecat
          vram limit - 180mb
            @shavecat Looks like the theme you're using is too heavy for a Pi - not enough VRAM available. Choose a lighter theme.
            • shavecatS
              shavecat
              crap :
              if i change the gpu_mem=320 its fixing it...
              not good?
                @shavecat Try it and see if anything else still works - i.e. if your N64 games crash or not.
                shavecatS 2 Replies Last reply Reply Quote 0
                • shavecatS
                  shavecat @mitu
                  i will thanks
                  • shavecatS
                    shavecat @mitu
                    not getting stuck or N64 games crash also not.
                    mituM quicksilverQ 2 Replies Last reply Reply Quote 0
                      @shavecat OK, then keep the setting for now and take note if you encounter any issues in the near future, just so you know what modifications you've done and be able to back them out.
                      • quicksilverQ
                        quicksilver @shavecat
                        @shavecat try using the default 256mb for vram. If you restore your config.txt back to stock settings it should be enabled by default. I have never had issues with vram set to 256mb.
                        IanDaemonI 1 Reply Last reply Reply Quote 1
                        • IanDaemonI
                          IanDaemon @quicksilver
                          @quicksilver said in Emulationstation theme give me gray box's...:
                          Isn't the default VRAM limit 400mb?
                          • Cocktail Cabinet Games
                          • Check out the MAME RoW
                            mitu Global Moderator @IanDaemon
                            @IanDaemon On a stock RetroPie image, the GPU allocated memory is 256Mb.
                            • quicksilverQ
                              quicksilver @IanDaemon
                              @IanDaemon default memory split is based on the amount of total ram on a particular model of pi. For Pi's with 1gb of of ram, 256mb is allocated to the GPU by default.
                              IanDaemonI 1 Reply Last reply Reply Quote 0
                              • IanDaemonI
                                @quicksilver Oh you're talking about the memory split, not the vram limit.
                                • quicksilverQ
                                  @IanDaemon yes, I was not referring to the vram limit. But on that subject vram limit on a pi with 1gb of ram is 944mb
                                  • IanDaemonI
                                    @quicksilver Do you happen to know how to test for memory on the Pi? I was updating and my house had a power fluctuation. I think something may be corrupted. Things work, just some things are slower.
                                    • quicksilverQ
                                      @IanDaemon
                                      from terminal run
                                      sudo apt-get install memtester
                                      sudo memtester 500 10
                                      You can change the "500" value to however much ram you want to test (in megabytes, remember some of your ram is taken up by the gpu). The "10" is the number of test loops.
                                      You want all tests to pass (ok)
                                      Edit: Now that I am re-reading your question are you asking how to check the sdram or sd card for errors?
                                      • IanDaemonI
                                        @quicksilver I was asking for the memory on the pi itself. Your answer was applicable. :)
