    New problem after setting up with new Raspian Stretch for background music?
    backgroundmusiemulationstatinoobwhy no sound
    12 Posts 2 Posters 795 Views
    • HankolaH
      Hankola
      I am using a RP3B with the newest retropie-4.4-rpi2_rpi3.img.
      I used the mpg123 method originally. I have edited all of the files correctly.
      My Autostart.sh reads:
      while pgrep omxplayer >/dev/null; do sleep 1; done
      (sleep 10; mpg123 -Z /home/pi/RetroPie/roms/music/*.mp3 >/dev/null 2>&1) &
      emulationstation #auto
      My runcommand-onend reads:
      mpg123 -Z /home/pi/RetroPie/roms/music/*.mp3 >/dev/null 2>&1 &
      My runcommand-onstart reads:
      pkill mpg123
      My music folder is in /home/pi/RetroPie/roms/music
      When I reboot the system it is telling me:
      /opt/retropie/configs/all/autostart.sh: line 4: syntax error: unexpected end of file
      what am I doing wrong?
        mitu Global Moderator @Hankola
        @Hankola said in New problem after setting up with new Raspian Stretch for background music?:
        There's an error on line 4 on your autostart.sh start-up script. How did you edit the file ?
        • HankolaH
          Hankola
          I dragged my old file from my previous pi set up. I copied file over the network connection.
            @Hankola Can you upload the file's contents on pastebin.com ? Make sure you open it with an editor that understands Unix line-endings (Notepad++).
            HankolaH 1 Reply Last reply Reply Quote 0
            • HankolaH
              Hankola @mitu
              @mitu I haven't ever done this; I am not very good at this stuff; just enough to get by. Do I create an account for this and then it gives me a nice copy for you to see?
                @Hankola There's no account needed on pastebin.com. Open the page and paste the contents of the file, submit it and then copy the browser's URL and paste it here.
                HankolaH 1 Reply Last reply Reply Quote 1
                • HankolaH
                  Hankola @mitu
                  @mitu https://pastebin.com/mjESkyrw
                    @Hankola Looks fine to me. Did you install mpg123 on your new system ? Run
                    sudo apt-get install mpg123
                    and see if your music comes back.
                    • HankolaH
                      Hankola @mitu
                      @mitu it's installed. So, on start up it pushes me out of ES and gives me the /opt/retropie/configs/all/autostart.sh:line4:systax error: unexpected end of file
                      If I type in the emulationstation at this point; it of course loads and then gives me no music, but it does bring stuff up. Then once I exit a game it gives me music after I come out. So I know the problem is somewhere in the autostart.sh ; but for the life of me I cannot find it.
                      • HankolaH
                        Hankola @Hankola
                        @mitu can I simply delete the autostart.sh file, reboot, retype? I think something in the file is wonky.
                          @Hankola Sure, remove it, then create it again with the lines you posted. Make sure you make it executable afterwards
                          chmod +x /opt/retropie/configs/all/autostart.sh
                          • HankolaH
                            Hankola
                            Ok, lesson learned. Copying stuff can lead to compounding errors. Thank you @mitu for the guidance!
