    Help with wireless usb keyboard
    keyboard usb
    1 Posts 1 Posters 179 Views
    • V
      voodoorida
      Hi.
      I'm looking for some help & advice.
      I have a wireless usb keyboard working alongside my wireless Xbox 360 controller. I have used this setup for a while now with a retropie image.
      But I am now having trouble with the same keyboard on a different retropie image.
      The pi recognises the keyboard as certain keys will register BUT it will not work properly....the keys do not register the correct letter/number etc.
      Is there a way of resetting to default.?
      Or how do I uninstall & then reinstall so the keyboard will work correctly?
      Many thanks
