    [SOLVED] Launching Images Not Working For Added ES System (I'm sometimes unable to read things correctly... Gah!)
    runcommandlaunching imageadded system
    3 Posts 2 Posters 769 Views
    • simpleethatS
      simpleethat
      I have this working for every other system on my pi (19 out of 20) but I can't seem to get my custom launching images to work for the TurgoGrafxCD system I created for ES. Before I separated regular TG16 & TGCD the launching images worked fine for every game.
      Post separation the videos and images while in EmulationStation work fine and the games play fine but when I launch I game I don't get the launching images I added to /roms/images. I have confirmed that the image filenames boths match the .cue filenames cue exactly and all have -launching appended before the extension. Is there something I have to edit with Runcommand to make launching images work for a non-stock system?
      Power Supply used: 5v 3A Northpada
      RetroPie Version Used: 4.4.5
      USB Devices connected: USB Game Pad & WD 2TB My Passport USB 3.0 HD
      Controller used: Hori Fighting Commander PS4
      Error messages received: none
      Log found in /dev/shm/runcommand.log (if relevant): fairly certain I might need somebody to walk me through finding this info, I can poke around in a PC fairly well but I am nowhere near as familiar with a Linux environment. (Anybody that wants to recommend a great crash course I would honestly appreciate that)
      Guide used: https://retropie.org.uk/docs/Add-a-New-System-in-EmulationStation/ & https://github.com/RetroPie/RetroPie-Setup/wiki/runcommand#adding-custom-launching-images
      File: I've tried this with almost each of the 45 files I have, they play fine I just get no launching images
      Emulator: lr-beetle-pce-fast
      Thank you to whomever can help me with this, in the meantime I think I'll just go ahead and try every game.
        Can you post the emulators.cfg file you created for the new system and the es_systems.cfg snippet you added ?
        simpleethatS 1 Reply Last reply Reply Quote 0
        • simpleethatS
          simpleethat @mitu
          @mitu I actually figured it out late last night. As I was trying every game file I thought that there had to be something wrong with how the images were being called up. I looked again at both my es_systems.cfg & emulators.cfg and realized that I had it pointing to pcengine not pcenginecd. I must have looked at those ten times without realizing my mistake.
          I knew I was doing something stupid. I guess I really should have stepped away from it for a bit.
