    Problem mounting network share
    network sharesamba share
    5 Posts 2 Posters 634 Views
      robmcc83
      Hi all.
      I'm using a raspberry pi 3 with 64gb SD Samsung Evo with official power supply.
      I have it housed in a retroflag snespi case.
      I have a 32gb SD for Kodi and a 64gb for my retropie which I just swap out for some gaming fun.
      My libreelec Kodi 32gb setup, is setup in a way that I mount my external HD that is connected to my internet router to the pi using cifs.
      Following libreelec wiki for mounting network shares this works fine.
      Now my cd based rom collection is getting bigger now almost filling my 64gb retropie SD card.
      So I've followed the wiki for mounting network shares but it doesn't seem to work (well it sort of does).
      I've added the line to autostart.sh that matches the information for my network share rebooted and the share is not mounted, but if if I ssh into my retropie and enter that line, then hit enter on my keyboard it mounts just fine, but then on next reboot it's no longer mounted.
      It appears it's not mounting the drive from the autostart.sh
      I've tried wait for network at boot but that also doesn't help.
      Anyone no what could be wrong here.
      Thanks in advance
      Rob
        mitu Global Moderator @robmcc83
        @robmcc83 What's the line you're using in autostart.sh ? If you exit ES, do you see any errors on the terminal related to the mount command ?
          robmcc83 @mitu
          I am using this line
          sudo mount -t cifs -o username=USERNAME,password=PASSWD,nounix,noserverino,vers=1.0 //192.168.1.254/Share/roms /home/pi/RetroPie/roms
          And no errors when exiting emulation station to terminal.
            @robmcc83 After you run the command manually, you say it works, but can the pi user access the folder ?
            Can you reboot, exit ES, then run mount and post the output ?
              robmcc83 @mitu
              Yes I can access the share no problem if I mount it manually with the pi user. It's just not mounting at boot.
              I'll have a check of mount later as I'm out all day.
              Rob
