    DIY EXPANDABLE Single/Multi-Player RetroPie ARCADE Gaming Console with OpenCADE - 3D Printed
    casejoystickopencadeconsolearcade
    18 Posts 3 Posters 3.6k Views
    • jonecoolJ
      jonecool
      OpenCADE has been released! This design will allow you to build your own RetroPie Arcade Console powered by a Raspberry Pi 3b/+. It's free for all to download, print and build. You can configure it a number of different ways, including:
      • 1-n Joysticks+Buttons for 1, 2, etc. players
      • Bases can be attached to each other to expand/grow as you want
      • Ability to add a USB port to the side (to attach a keyboard, trackball or spinner without opening the case) or simply add a cover plate.
      • Ability to simply install an encoder board and route the USB cable outside the base in case you don't want to install the RPi in the case.
      • Blank control panel so that you can modify it by placing buttons however you want.
      • Base that has no front buttons in case you don't want them on the front.
      • Additional expansion options are planned .
      Please comment below if you want to see any future enhancements. I have a few ideas which I'll be releasing as they are designed. Be sure to watch the end of the video for a preview of another customization that's coming.
      Video Tutorial and Thingiverse Download links here:
      Download / Details: http://wagnerstechtalk.com/opencade
      Video Only:
      Here are some pics of a 1-player, 2-player, USB Plate, etc.:
      • Thorr69T
        Thorr69
        I dig the concept. I'd like to see the idea expanded into just a controller that you could perhaps have twin sticks or a trackball. And, perhaps a larger footprint to give your hands a place to rest. It has my mind working, that's for sure.
        RPi 3b
        Official PSU
        Official RetroPie image
        Pandora's Box 5 controller
        jonecoolJ 1 Reply Last reply Reply Quote 1
        • jonecoolJ
          jonecool
          Thank you for your feedback!
          You can definitely setup twin sticks as it is now. Just print two bases+cp's and assemble them side-by-side like you see towards the middle-end of the video. Do I hear Robotron now being playable? Yep! Regarding the trackball, already working on that one too (mine arrived just yesterday for developing the assembly). Please see the advantages here where it is mentioned.
          I'm also considering making an expansion pack that has just a single joystick on one control panel (left) and the buttons on the other (right). That gives you more physical space and hand-rest. I'm also going to provide a completely blank control panel (with screw holes), so anyone could configure it how they want. In the current package, I have somewhat done that by providing the joystick-only and no buttons. But, I think a totally blank panel makes sense.
          • Thorr69T
            Thorr69
            By twin sticks, I mean 2 sticks for 1 player. This type of control is used for games like Robotron2084 and Krull. You mention it, but I am thinking of you just taking the stick template with blank buttons and putting a second stick where the buttons would go. This would interfere with the pie, but if it's just a controller then it would be fine
            RPi 3b
            Official PSU
            jonecoolJ 2 Replies Last reply Reply Quote 0
            • jonecoolJ
              jonecool @Thorr69
              @Thorr69 Got it, but yes you can still do this. I built a MAME cab with 1&2 players. Just go into MAME and setup Player 1 stick for movement of the character and stick 2 for the fire directions. Doesn't require a single panel with both sticks on it. Just use a 2 player build for this. At least, that's my recommendation - it works fine that way with the advantage of being able to play all other games.
              Are you thinking of building a Robotron-only unit? If that's the case, it could still be done with a slight mod to the control panel to duplicate the joystick layout and the few buttons.
              • Thorr69T
                Thorr69 @jonecool
                @jonecool
                You got your reply in before I was done. =)
                My sugesstion for a bigger palm plate could be implemented as a front panel extension that you could print up and then attach (much like you do the side panel).
                RPi 3b
                Official PSU
                jonecoolJ 1 Reply Last reply Reply Quote 0
                • jonecoolJ
                  jonecool @Thorr69
                  @Thorr69 That's a good idea! I'll put this on my todo list, I like it :)
                  • jonecoolJ
                    jonecool @Thorr69
                    @Thorr69 This weekend I spent some time on a concept for providing more room for your wrist to rest on. Printed it and tested it out, since it uses the side plate cover for support concept you mentioned (completely replaces the side cover - same screw holes/dimensions) it is very sturdy and holds up well. I have another version printing that is a bit sleeker, but wanted to get your thoughts on this design to your point of having a larger footprint for your hands to rest.
                    I've also prototyped/printed the dual-joystick control panel but haven't installed/tested it yet (new stick ordered that arrived today). I'll post back once I do, next couple days.
                    Trackball will be started once I can get the software setup/working and verify it works before starting the model. Software may take me awhile to figure out. Messed with it some this weekend and it's a bit more involved, apparently. Printed the official docs, just need to go through them and figure it all out/test.
                    • Thorr69T
                      Thorr69
                      Hmmm. Well, the approach you took is quite interesting. I like that you made a module that works with your current build. My only comment is that it's on the opposite side of where I had envisioned. =D It's the button array that really needs the support. Like many people, I plant the heel of my hand down while I am using a mouse or playing an arcade game. The height of the box makes that largely impossible, particularly with how close the button array is to the front edge of the unit. It's particularly tiresome when play a shmup and you are railing on only 1 or 2 buttons and your arm isn't supported. Here is what I currently am using (while I am working out a full arcade implementation): http://www.8bitdo.com/n30-arcade-stick/
                      The front image on that page shows where hand placement is for most people. The unit looks to have good distance between the lowest button and the bevel of the front edge. (The dark portion is flat, the light gray edge is beveled down.) Even in this position, the heel of her hand is on the bevel. (This image could easily be my wife. She stopped playing Galaga with me on this unit because there's no support for her hand.) The height of this unit is about 2 inches, which I think is shorter than your box design. This stick doesn't have enough space for comfort.
                      This shelf is still very useful because it gives your stick hand some spreading room. For games like Pac-Man and other non-firing games, this is perfectly good.
                      My implementation would be a blank box in the same shape as your current version, but at a height equal to the front edge. It would sit in front and be a place for the heels of your hand to rest. The box could have a rear cutout to accommodate the front p1/p2 buttons of the main unit. (personally, I wouldn't build those buttons on the front anyway.) It doesn't have to attach, per se, since you may not always want it there. (You could still have a side attachment port like the main box so that a 2-player implementation would work the same way as the main boxes do.)
                      Anyway, just my thoughts. Keep up the good work. =)
                      RPi 3b
                      Official PSU
                      • jonecoolJ
                        jonecool @Thorr69
                        @Thorr69 Thank you again for your feedback! Wrist support extensions for the button panel. In fact, this panel can be used with a 2-player configuration and is of course optional. If you wanted one or the other or both, you could easily configure it however you want.
                        I'm also going to design the joystick-only panel and separate button panel that was mentioned earlier. That will give anyone options on how they wish to configure their OpenCADE.
                        Haven't yet tested the Robotron console, I'll get to that soon as well. After that, trackball!
                        • Thorr69T
                          Thorr69
                          Nice! I like the way you attached it to the under pinnings of the front. Have you tested the strength of it?
                          RPi 3b
                          Official PSU
                          • jonecoolJ
                            jonecool @Thorr69
                            @Thorr69 It was sturdy, but I found a better way to go that works with any configuration. The above worked just fine, but was limited to a 1-player only configuration as it would expose the support bar if used on a 2-player setup. Instead of having two different designs, just going to scrap the above but use the core elements to create one that works with 1 base or 2+ bases. Finished designing the control panels for a joystick on the left panel and buttons on the right. This really gives you the ultimate flexibility in building an arcade control panel. I'll have real pictures soon, it's printing now...
                            New Control Panel for a larger 1-player configuration:
                            • BillyHB
                              BillyH
                              Not to rain on anyone's parade, but shouldn't this topic be in the projects subforum? It'll probably get more views too there from people specifically looking for this kind of threads.
                              • First Pi: Pi 3 in a PSone case
                              • Second Pi: Pi 0 in a Retroflag GPi Case
                              • Third Pi: Pi 4 as a desktop computer
                              • Some time in 2020: Picade
                              • Thorr69T
                                Thorr69 @jonecool
                                @jonecool I like it!!!! Every little bit of support helps. This iteration is clean and modular. I totally dig it!
                                RPi 3b
                                Official PSU
                                • jonecoolJ
                                  jonecool @Thorr69
                                  @Thorr69 I took your recommendation and made it so :) Robotron 2084 playing in an OpenCADE console. One minor change to make and that's the cutout in the back needs to be a little deeper to support 2 USB encoders. The reason is, you can't connect 2 joysticks up to one encoder (at least, the set I purchased). So, there are two sticks, 2 encoders and 2 cables from the box. Also, each controller must have one button assigned to each of the sticks or it's impossible to configure the stick in RetroPie (and in MAME).
                                  After adding 2 encoders, I then mapped the left button to insert a coin and the right button to start the game. Works perfectly, you'd need to add another button on the left/right of the box to be able to navigate RetroPie. But, the project is a success! Files will be uploaded once I do more testing and document how to set it all up.
                                  Oh, new suction cup holders for the base too...
                                  • Thorr69T
                                    Thorr69
                                    Very nice! Pretty much exactly how I pictured it!
                                    RPi 3b
                                    Official PSU
                                    • jonecoolJ
                                      jonecool @Thorr69
                                      @Thorr69 This is what the pieces look like printed for a single player extended configuration. It could also easily have been a 2-player extended but I'm wanting to try some new designs for the stick+buttons on separate panels :) Of course, you can also use the suction cup holders (above) to secure it as well. Getting close to a release, just need to fully assemble with stick+buttons and test it out.
                                      • jonecoolJ
                                        jonecool @jonecool
                                        The Expansion Pack has been released on Thingiverse: https://www.thingiverse.com/thing:3491239
                                        Additional Details can be found here.
