    USB drive randomly not showing up until reboot
    usb romsusb issuestroubleshooting
    27 Posts 3 Posters 3.2k Views
    • ZioDarkmageZ
      ZioDarkmage
      I am running RetroPie 4.4 on a Pi 3B+ with the RetroFlag MegaDrive case. I have my roms on a Samsung Fit Drive 256gB thumb drive. When I plug the usb drive directly into the hidden compartment ports of the case (The pi usb ports directly next to the Ethernet adapter) I have to soft reboot the pi before the roms will show up. If I plug the drive into the front extensions on the case (The extenders connected to the usb ports on the pi farthest from the Ethernet port) the roms show up immediately. I do have the RetroFlag safe shut down script installed, but that does not seem to be the issue as it only seems to affect one set of USB ports. The Pi itself is less than a month old and the image for RetroPie is a new imaging on a new micro SD card.
      Is this a possible issue with the Pi itself, or should I add a delay into the boot config or what?
      Any advice is appreciated.
      • ZioDarkmageZ
        ZioDarkmage
        Did a bit more troubleshooting. I have done a complete hardware swap out, pie, case, microsd, flashdrive, and power supply. Used balena etcher on a fresh retropie 4.4 download instead of the win disk writer, and a brand new microsd card adapter, and the same thing is occurring once I perform the update Retropie script and update the packages. It will act fine for a while, then I connected a Bluetooth controller and connected it to my WiFi and changed the theme now its doing it again on basically a completely different unit. This is a real head scratchier for me. I am unsure how to proceed, and any advice would be greatly appreciated, as this is the first time in this has happened to me and I have been using RetroPie for a while now.
        • HalvhjearneH
          Halvhjearne
          @ZioDarkmage
          i had the same problem and it seems usbmount is somewhat unreliable and far from always works as intended, in fact i found it works best when the system is already booted or when/if you dont need it, not to mention that reading from usb can be quite slow sometimes for various reasons.
          you could just mount it via fstab, and remove usbmount, then it will always be mounted on boot.
          but if the drive fails, you reformat it or otherwise change something vital in the folder structure, retropie will not boot without editing fstab again.
          • EfriimE
            Efriim @ZioDarkmage
            @ZioDarkmage
            I have the same case and pi.
            I just wrote about adding ftsab here.
            I notice also that usb's won't mount until startx or desktop, this using the front usb extension, maybe left or right. I don't know about the automount scripts or where to look for them. I ramble on a bit but fstab will be a good solution.
            Since you're using it particularly dedicated for roms, you could change the fstab to mount the usb on /home/pi/RetroPie/roms/ and that would do away with needing to create symlinks.
            This Sony Memory card fits bloody well in there.
            • ZioDarkmageZ
              ZioDarkmage
              @Halvhjearne and @Efriim
              Thank you for the advice.
              The fstab mount does seem more stable but I noticed that when I attempted to set the splashscreen as a file that would not load (a gif in this instance) from the flash drive, that emulationstation did not recognize any of the roms, and the samba share showed the folders as empty like it did before.
              This has me curious as to if it may be a delay needing to be added as the splashscreen attempted to load the file from the flash drive but on failure it had issue. I am going to continue to experiment on it and see if I can determine the cause. Ultimately it appears that the issue is occurring just before the launch of emulationstation and after attempting to load the splashscreen.
              HalvhjearneH 1 Reply Last reply Reply Quote 0
              • HalvhjearneH
                Halvhjearne @ZioDarkmage
                @ZioDarkmage
                sounds like its not mounted correctly, perhaps wrong folder or read only, but its hard to say without knowing what exactly you did now.
                • EfriimE
                  Efriim
                  You're welcome Zio.
                  I read recently in a lateral thread there was an issue with the usbromservice mounting with root permissions, it is as easy as removing the package with RetroPie manager, maybe that will help.
                  When I used fstab
                  [share or device id]       [mount directory]      [fs] [mountoptions]               [dump] [fsck]
                  UUID=____-____             /home/pi/RetroPie/roms vfat nofail,user,uid=pi,gid=pi    0      2
                  I used userid "pi" and it doesn't have any trouble loading roms even with symlinks.
                  I got like a 16 second boot speed. There shouldn't be any delay, but I also have the usbromservice uninstalled.
                  UUID=Universal unique Identifier, use sudo blkid /dev/sda1 or ls -l /dev/disk/by-uuid
                  note: you can also mount server shares or device by label
                  //server/share/
                  LABEL=
                  they are all mounted by availability, so if the system daemon doesn't read anything here it doesn't cause issues.
                  Mount Directory, the root of the device partition will be mounted here. I don't know how to mount a specific folder from the device partition. I don't know about layering either, I think it is done in --options
                  mount --options, there are a lot of mount options seperated by a comma. I think I added noatime to my systemroot, so that it doesn't update access times.
                  dump, system backup dump seldom used; 0 by default
                  fsck, filesystem check pass order; 0 1 or 2; 0 pass no check, 1 for the root filesystem, 2 for last used for everything else.
                  • ZioDarkmageZ
                    ZioDarkmage
                    @Efriim
                    Thank you for the detailed info on that. I fully uninstalled the usbrom service this time instead of just disabling it and it seems to be fully stable now. I will keep testing it for a few more days just to double check but I think this may have solved it.
                    • HalvhjearneH
                      @ZioDarkmage
                      you definitely need to remove usbmount service completely, if you use fstab (but tbh i assumed you already did that) or it will mount the folder retropie-mount if it exsits and even if you disable it, it will do the same again, after you update next.
                      also, mounting with the build in service uses the folder retropie-mount, but when using fstab, it is a lot easier if you move everything out from that folder, or you will need to mount folders in folders.
                      @Efriim said in USB drive randomly not showing up until reboot:
                      the last number is the order it checks the drives, hence if you have multiple drives it will check in numeric order or if same number is used, it will check in the order it is written in fstab
                      • ZioDarkmageZ
                        ZioDarkmage
                        Just got home from work, booted up, the theme crashed and required the power to be unplugged, booted it back up and its doing it again. This is the USB I am using : Samsung 256gb USB 3.1 At this point I am really doubting myself on this, as when it occurs, I use the ls -l /dev/disk/by-uuid and it is not showing up at all until I do a sudo reboot. I am even resetting the rom permissions in the RetroPie Setup menu and nothing seems to impact it. I know USB 3.1 should be backwards compatible with the USB 2.0 ports and visa versa, I have used a USB 3.0 hdd and had no issue, just on flash drives am I having issues.
                        EfriimE HalvhjearneH 2 Replies Last reply Reply Quote 0
                        • EfriimE
                          Efriim @ZioDarkmage
                          @ZioDarkmage
                          The theme crashed? What is your vram limit and gpu mem?
                          • HalvhjearneH
                            @ZioDarkmage
                            for some reason some usb sticks needs a "hardboot" to wakeup after being in a standby state, but iirc the pi should shut off power to the usb when its powered down.
                            are you sure its a genuine samsung usb stick?
                            how much has it been used before?
                            has it been written to many times or maybe just sitting in the usbport of a computer for a long time maybe?
                            also, what type of sd card do you use?
                            and what kind of power supply?
                            • ZioDarkmageZ
                              ZioDarkmage
                              @Halvhjearne
                              As far as I can tell its genuine as the seller on Amazon is listed as Samsung. And it matches the other Samsung I picked up at MicroCenter.
                              The power supply is the Official Raspberry Pi Foundation Power Supply that I got from MicroCenter. As for the micro sd card, I am using a Samsung EVO 32gb class 10. It is the orange one from before the red/green line up of Samsung micro sd's. I have about 5 of them laying around and have tried different ones, I have even tried a SanDisk 32gb. The flash drive is less than a month old, was sealed, works fine popping it into a pc with no issues. Other than transferring the roms to it and playing games on my pi, it hasn't really been used. I did notice that it seems to be consistent with the usb being "cold" (relative speaking, the house stays at about 70°F / 21°C) or after emulationstation stutters upon changing between themes without a restart in between. I do know that I can plug the flash drive into the usb ports on the front of the case and it hasn't happened once with that set up, but I am trying to keep it plugged directly to the board so it can not be removed easily.
                              And once again thank you for any advice and looking into this thread.
                              • EfriimE
                                Efriim @ZioDarkmage
                                @ZioDarkmage
                                What does your boot time look like?
                                systemd-analyze
                                Also try
                                dmesg
                                and try to relay any errors you see or espescially long time intervals.
                                You could try a different scheduler for the USB drive by inserting this line into
                                /etc/rc.local
                                echo "noop" > /sys/block/sda/queue/scheduler
                                reboot and confirm if it worked with
                                cat /sys/block/sda/queue/scheduler
                                noop should be perfectly suitable for flash devices, it is basically first in first out, and no optimizations for disk seeking.
                                • ZioDarkmageZ
                                  ZioDarkmage
                                  @Efriim
                                  My fstab:
                                  proc            /proc           proc    defaults          0       0
                                  PARTUUID=f2d3cb4f-01  /boot           vfat    defaults          0       2
                                  PARTUUID=f2d3cb4f-02  /               ext4    defaults,noatime  0       1
                                  # a swapfile is not a swap partition, no line here
                                  #   use  dphys-swapfile swap[on|off]  for that
                                  # Establish the drive's UUID number by entering the command ls -l /dev/disk/by-$
                                  UUID=4B03-03C9  /home/pi/RetroPie/roms      vfat    nofail,user,uid=pi,gid=pi 0 2
                                  My systemd-analyze:
                                  pi@retropie:~ $ systemd-analyze
                                  Startup finished in 1.482s (kernel) + 33.655s (userspace) = 35.138s
                                  The next one is really long and I apologize as I am unsure the exact info needed so I am posting all of it.
                                  My dmesg:
                                  pi@retropie:~ $ dmesg
                                  [    0.000000] Booting Linux on physical CPU 0x0
                                  [    0.000000] Linux version 4.14.98-v7+ (dom@dom-XPS-13-9370) (gcc version 4.9.        3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1200 SMP Tue Feb 12 20:27:48        GMT 2019
                                  [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
                                  [    0.000000] CPU: div instructions available: patching division code
                                  [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio        n cache
                                  [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
                                  [    0.000000] Memory policy: Data cache writealloc
                                  [    0.000000] cma: Reserved 8 MiB at 0x2f800000
                                  [    0.000000] On node 0 totalpages: 196608
                                  [    0.000000] free_area_init_node: node 0, pgdat 80c85780, node_mem_map af13400        0
                                  [    0.000000]   Normal zone: 1728 pages used for memmap
                                  [    0.000000]   Normal zone: 0 pages reserved
                                  [    0.000000]   Normal zone: 196608 pages, LIFO batch:31
                                  [    0.000000] percpu: Embedded 17 pages/cpu @af0dd000 s38720 r8192 d22720 u6963        2
                                  [    0.000000] pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*4096
                                  [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                                  [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 194880
                                  [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2        708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_s        ize=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty3 root=PART        UUID=f2d3cb4f-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait logl        evel=3 consoleblank=0 plymouth.enable=0
                                  [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
                                  [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
                                  [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
                                  [    0.000000] Memory: 757532K/786432K available (7168K kernel code, 577K rwdata        , 2080K rodata, 1024K init, 698K bss, 20708K reserved, 8192K cma-reserved)
                                  [    0.000000] Virtual kernel memory layout:
                                                     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                                                     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                                                     vmalloc : 0xb0800000 - 0xff800000   (1264 MB)
                                                     lowmem  : 0x80000000 - 0xb0000000   ( 768 MB)
                                                     modules : 0x7f000000 - 0x80000000   (  16 MB)
                                                       .text : 0x80008000 - 0x80800000   (8160 kB)
                                                       .init : 0x80b00000 - 0x80c00000   (1024 kB)
                                                       .data : 0x80c00000 - 0x80c906d4   ( 578 kB)
                                                        .bss : 0x80c97ef8 - 0x80d468f0   ( 699 kB)
                                  [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                                  [    0.000000] ftrace: allocating 25298 entries in 75 pages
                                  [    0.000000] Hierarchical RCU implementation.
                                  [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                                  [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
                                  [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:        0x46d987e47, max_idle_ns: 440795202767 ns
                                  [    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 43980        46511078ns
                                  [    0.000018] Switching to timer-based delay loop, resolution 52ns
                                  [    0.000266] Console: colour dummy device 80x30
                                  [    0.000285] console [tty3] enabled
                                  [    0.000310] Calibrating delay loop (skipped), value calculated using timer fr        equency.. 38.40 BogoMIPS (lpj=192000)
                                  [    0.000325] pid_max: default: 32768 minimum: 301
                                  [    0.000648] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
                                  [    0.000663] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
                                  [    0.001605] Disabling memory control group subsystem
                                  [    0.001682] CPU: Testing write buffer coherency: ok
                                  [    0.002100] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                                  [    0.002508] Setting up static identity map for 0x100000 - 0x10003c
                                  [    0.002631] Hierarchical SRCU implementation.
                                  [    0.003310] smp: Bringing up secondary CPUs ...
                                  [    0.004091] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                                  [    0.004936] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                                  [    0.005763] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                                  [    0.005869] smp: Brought up 1 node, 4 CPUs
                                  [    0.005880] SMP: Total of 4 processors activated (153.60 BogoMIPS).
                                  [    0.005885] CPU: All CPU(s) started in HYP mode.
                                  [    0.005890] CPU: Virtualization extensions available.
                                  [    0.006776] devtmpfs: initialized
                                  [    0.017240] random: get_random_u32 called from bucket_table_alloc+0xfc/0x24c        with crng_init=0
                                  [    0.017981] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3        rev 4
                                  [    0.018204] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 19112604462750000 ns
                                  [    0.018221] futex hash table entries: 1024 (order: 4, 65536 bytes)
                                  [    0.018778] pinctrl core: initialized pinctrl subsystem
                                  [    0.019539] NET: Registered protocol family 16
                                  [    0.022259] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                                  [    0.027225] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint        registers.
                                  [    0.027232] hw-breakpoint: maximum watchpoint size is 8 bytes.
                                  [    0.027439] Serial: AMBA PL011 UART driver
                                  [    0.029096] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
                                  [    0.029557] uart-pl011 3f201000.serial: could not find pctldev for node /soc/        gpio@7e200000/uart0_pins, deferring probe
                                  [    0.061480] bcm2835-dma 3f007000.dma: DMA legacy API manager at b0813000, dma        chans=0x1
                                  [    0.062934] SCSI subsystem initialized
                                  [    0.063156] usbcore: registered new interface driver usbfs
                                  [    0.063207] usbcore: registered new interface driver hub
                                  [    0.063295] usbcore: registered new device driver usb
                                  [    0.070082] raspberrypi-firmware soc:firmware: Attached to firmware from 2019        -02-12 19:42
                                  [    0.071493] clocksource: Switched to clocksource arch_sys_counter
                                  [    0.148260] VFS: Disk quotas dquot_6.6.0
                                  [    0.148342] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                                  [    0.148526] FS-Cache: Loaded
                                  [    0.148709] CacheFiles: Loaded
                                  [    0.156769] NET: Registered protocol family 2
                                  [    0.157484] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
                                  [    0.157594] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
                                  [    0.157779] TCP: Hash tables configured (established 8192 bind 8192)
                                  [    0.157907] UDP hash table entries: 512 (order: 2, 16384 bytes)
                                  [    0.157951] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
                                  [    0.158178] NET: Registered protocol family 1
                                  [    0.158646] RPC: Registered named UNIX socket transport module.
                                  [    0.158652] RPC: Registered udp transport module.
                                  [    0.158657] RPC: Registered tcp transport module.
                                  [    0.158662] RPC: Registered tcp NFSv4.1 backchannel transport module.
                                  [    0.160292] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counter        s available
                                  [    0.163062] workingset: timestamp_bits=14 max_order=18 bucket_order=4
                                  [    0.171221] FS-Cache: Netfs 'nfs' registered for caching
                                  [    0.171862] NFS: Registering the id_resolver key type
                                  [    0.171895] Key type id_resolver registered
                                  [    0.171901] Key type id_legacy registered
                                  [    0.171916] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                                  [    0.173866] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        51)
                                  [    0.173997] io scheduler noop registered
                                  [    0.174004] io scheduler deadline registered (default)
                                  [    0.174171] io scheduler cfq registered
                                  [    0.174178] io scheduler mq-deadline registered
                                  [    0.174183] io scheduler kyber registered
                                  [    0.176533] BCM2708FB: allocated DMA memory ef900000
                                  [    0.176560] BCM2708FB: allocated DMA channel 0 @ b0813000
                                  [    0.234465] Console: switching to colour frame buffer device 240x67
                                  [    0.269449] bcm2835-rng 3f104000.rng: hwrng registered
                                  [    0.269583] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000        000(1024 MiB)
                                  [    0.270028] vc-sm: Videocore shared memory driver
                                  [    0.270305] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f2        00000
                                  [    0.280172] brd: module loaded
                                  [    0.289313] loop: module loaded
                                  [    0.289328] Loading iSCSI transport class v2.0-870.
                                  [    0.290055] libphy: Fixed MDIO Bus: probed
                                  [    0.290158] usbcore: registered new interface driver lan78xx
                                  [    0.290219] usbcore: registered new interface driver smsc95xx
                                  [    0.290234] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                                  [    0.318140] dwc_otg 3f980000.usb: base=0xf0980000
                                  [    0.518364] Core Release: 2.80a
                                  [    0.518376] Setting default values for core params
                                  [    0.518409] Finished setting default values for core params
                                  [    0.718679] Using Buffer DMA mode
                                  [    0.718686] Periodic Transfer Interrupt Enhancement - disabled
                                  [    0.718690] Multiprocessor Interrupt Enhancement - disabled
                                  [    0.718698] OTG VER PARAM: 0, OTG VER FLAG: 0
                                  [    0.718710] Dedicated Tx FIFOs mode
                                  [    0.719037] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xaf9        14000 dma = 0xef914000 len=9024
                                  [    0.719063] FIQ FSM acceleration enabled for :
                                                 Non-periodic Split Transactions
                                                 Periodic Split Transactions
                                                 High-Speed Isochronous Endpoints
                                                 Interrupt/Control Split Transaction hack enabled
                                  [    0.719070] dwc_otg: Microframe scheduler enabled
                                  [    0.719125] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805ed94c
                                  [    0.719136] WARN::hcd_init_fiq:460: FIQ ASM at 0x805edcb4 length 36
                                  [    0.719151] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
                                  [    0.719204] dwc_otg 3f980000.usb: DWC OTG Controller
                                  [    0.719236] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number        1
                                  [    0.719268] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
                                  [    0.719317] Init: Port Power? op_state=1
                                  [    0.719323] Init: Power Port (0)
                                  [    0.719547] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
                                  [    0.719558] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
                                  [    0.719567] usb usb1: Product: DWC OTG Controller
                                  [    0.719575] usb usb1: Manufacturer: Linux 4.14.98-v7+ dwc_otg_hcd
                                  [    0.719583] usb usb1: SerialNumber: 3f980000.usb
                                  [    0.720185] hub 1-0:1.0: USB hub found
                                  [    0.720226] hub 1-0:1.0: 1 port detected
                                  [    0.720775] dwc_otg: FIQ enabled
                                  [    0.720780] dwc_otg: NAK holdoff enabled
                                  [    0.720785] dwc_otg: FIQ split-transaction FSM enabled
                                  [    0.720795] Module dwc_common_port init
                                  [    0.721056] usbcore: registered new interface driver usb-storage
                                  [    0.721222] mousedev: PS/2 mouse device common for all mice
                                  [    0.721298] IR NEC protocol handler initialized
                                  [    0.721303] IR RC5(x/sz) protocol handler initialized
                                  [    0.721308] IR RC6 protocol handler initialized
                                  [    0.721313] IR JVC protocol handler initialized
                                  [    0.721318] IR Sony protocol handler initialized
                                  [    0.721323] IR SANYO protocol handler initialized
                                  [    0.721328] IR Sharp protocol handler initialized
                                  [    0.721333] IR MCE Keyboard/mouse protocol handler initialized
                                  [    0.721338] IR XMP protocol handler initialized
                                  [    0.722086] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
                                  [    0.722357] bcm2835-cpufreq: min=600000 max=1400000
                                  [    0.722718] sdhci: Secure Digital Host Controller Interface driver
                                  [    0.722723] sdhci: Copyright(c) Pierre Ossman
                                  [    0.723086] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
                                  [    0.723417] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
                                  [    0.723511] sdhci-pltfm: SDHCI platform and OF driver helper
                                  [    0.724928] ledtrig-cpu: registered to indicate activity on CPUs
                                  [    0.725085] hidraw: raw HID events driver (C) Jiri Kosina
                                  [    0.725238] usbcore: registered new interface driver usbhid
                                  [    0.725243] usbhid: USB HID core driver
                                  [    0.725863] vchiq: vchiq_init_state: slot_zero = af980000, is_master = 0
                                  [    0.727412] [vc_sm_connected_init]: start
                                  [    0.737136] [vc_sm_connected_init]: end - returning 0
                                  [    0.737738] Initializing XFRM netlink socket
                                  [    0.737764] NET: Registered protocol family 17
                                  [    0.737865] Key type dns_resolver registered
                                  [    0.738380] Registering SWP/SWPB emulation handler
                                  [    0.738987] registered taskstats version 1
                                  [    0.745045] uart-pl011 3f201000.serial: cts_event_workaround enabled
                                  [    0.745127] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud        = 0) is a PL011 rev2
                                  [    0.747081] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
                                  [    0.747092] mmc-bcm2835 3f300000.mmc: DMA channel allocated
                                  [    0.802128] sdhost: log_buf @ af913000 (ef913000)
                                  [    0.838989] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                                  [    0.840559] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                  [    0.842125] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                  [    0.844902] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                                  [    0.881515] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
                                  [    0.882603] of_cfs_init
                                  [    0.882691] of_cfs_init: OK
                                  [    0.903795] Waiting for root device PARTUUID=f2d3cb4f-02...
                                  [    0.923112] random: fast init done
                                  [    0.930242] mmc1: new high speed SDIO card at address 0001
                                  [    0.931647] Indeed it is in host mode hprt0 = 00021501
                                  [    0.998523] mmc0: host does not support reading read-only switch, assuming wr        ite-enable
                                  [    1.001295] mmc0: new high speed SDHC card at address 0001
                                  [    1.001840] mmcblk0: mmc0:0001 BB1QT 29.8 GiB
                                  [    1.003274]  mmcblk0: p1 p2
                                  [    1.025470] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O        pts: (null)
                                  [    1.025528] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                  [    1.026294] devtmpfs: mounted
                                  [    1.029671] Freeing unused kernel memory: 1024K
                                  [    1.141553] usb 1-1: new high-speed USB device number 2 using dwc_otg
                                  [    1.141708] Indeed it is in host mode hprt0 = 00001101
                                  [    1.381828] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
                                  [    1.381854] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                                  [    1.382603] hub 1-1:1.0: USB hub found
                                  [    1.382714] hub 1-1:1.0: 4 ports detected
                                  [    1.529618] systemd[1]: System time before build time, advancing clock.
                                  [    1.659050] NET: Registered protocol family 10
                                  [    1.660186] Segment Routing with IPv6
                                  [    1.669880] ip_tables: (C) 2000-2006 Netfilter Core Team
                                  [    1.687171] random: systemd: uninitialized urandom read (16 bytes read)
                                  [    1.692791] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SEL        INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +        XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
                                  [    1.693377] systemd[1]: Detected architecture arm.
                                  [    1.701552] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
                                  [    1.702722] systemd[1]: Set hostname to <retropie>.
                                  [    1.738059] random: systemd: uninitialized urandom read (16 bytes read)
                                  [    1.757905] random: systemd-cryptse: uninitialized urandom read (16 bytes rea        d)
                                  [    1.841954] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514
                                  [    1.841973] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber        =0
                                  [    1.842685] hub 1-1.1:1.0: USB hub found
                                  [    1.842769] hub 1-1.1:1.0: 3 ports detected
                                  [    2.294634] systemd[1]: Listening on Journal Socket.
                                  [    2.296167] systemd[1]: Set up automount Arbitrary Executable File Formats Fi        le System Automount Point.
                                  [    2.296781] systemd[1]: Listening on udev Control Socket.
                                  [    2.297213] systemd[1]: Listening on fsck to fsckd communication Socket.
                                  [    2.298207] systemd[1]: Created slice User and Session Slice.
                                  [    2.298652] systemd[1]: Listening on udev Kernel Socket.
                                  [    2.299059] systemd[1]: Listening on Syslog Socket.
                                  [    2.926991] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                  [    3.007943] systemd-journald[91]: Received request to flush runtime journal f        rom PID 1
                                  [    3.401816] snd_bcm2835: module is from the staging directory, the quality is        unknown, you have been warned.
                                  [    3.418458] bcm2835_alsa bcm2835_alsa: card created with 8 channels
                                  [    3.596643] brcmfmac: F1 signature read @0x18000000=0x15264345
                                  [    3.606143] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43455-sdi        o.bin for chip 0x004345(17221) rev 0x000006
                                  [    3.606589] usbcore: registered new interface driver brcmfmac
                                  [    3.923803] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Feb 27 2        018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
                                  [    3.924561] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 9.        10.105 Compiler: 1.29.4 ClmImport: 1.36.3 Creation: 2018-03-09 18:56:28
                                  [    5.076877] uart-pl011 3f201000.serial: no DMA platform data
                                  [    5.335185] Adding 102396k swap on /var/swap.  Priority:-2 extents:2 across:1        61788k SSFS
                                  [    5.468368] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
                                  [    5.468406] brcmfmac: power management disabled
                                  [    8.681089] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                                  [   11.745573] Bluetooth: Core ver 2.22
                                  [   11.745680] NET: Registered protocol family 31
                                  [   11.745687] Bluetooth: HCI device and connection manager initialized
                                  [   11.745713] Bluetooth: HCI socket layer initialized
                                  [   11.745728] Bluetooth: L2CAP socket layer initialized
                                  [   11.745765] Bluetooth: SCO socket layer initialized
                                  [   11.765591] Bluetooth: HCI UART driver ver 2.3
                                  [   11.765609] Bluetooth: HCI UART protocol H4 registered
                                  [   11.765616] Bluetooth: HCI UART protocol Three-wire (H5) registered
                                  [   11.765860] Bluetooth: HCI UART protocol Broadcom registered
                                  [   11.928419] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                  [   11.928429] Bluetooth: BNEP filters: protocol multicast
                                  [   11.928443] Bluetooth: BNEP socket layer initialized
                                  [   17.652410] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
                                  [   17.652454] Bluetooth: HIDP socket layer initialized
                                  [   17.712814] sony 0005:054C:05C4.0001: unknown main item tag 0x0
                                  [   17.717580] input: Wireless Controller Touchpad as /devices/platform/soc/3f20        1000.serial/tty/ttyAMA0/hci0/hci0:11/0005:054C:05C4.0001/input/input1
                                  [   17.717710] input: Wireless Controller Motion Sensors as /devices/platform/so        c/3f201000.serial/tty/ttyAMA0/hci0/hci0:11/0005:054C:05C4.0001/input/input2
                                  [   17.718259] input: Wireless Controller as /devices/platform/soc/3f201000.seri        al/tty/ttyAMA0/hci0/hci0:11/0005:054C:05C4.0001/input/input0
                                  [   17.718452] sony 0005:054C:05C4.0001: input,hidraw0: BLUETOOTH HID v81.00 Gam        epad [Wireless Controller] on b8:27:eb:c1:c8:2d
                                  [   22.380112] dwc_otg_handle_wakeup_detected_intr lxstate = 2
                                  [   22.831596] usb 1-1.1: reset high-speed USB device number 3 using dwc_otg
                                  [   23.201599] usb 1-1.1: USB disconnect, device number 3
                                  [   23.301566] usb 1-1.1: new high-speed USB device number 4 using dwc_otg
                                  [   23.431789] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514
                                  [   23.431802] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber        =0
                                  [   23.432340] hub 1-1.1:1.0: USB hub found
                                  [   23.432408] hub 1-1.1:1.0: 3 ports detected
                                  [   23.531568] usb 1-1.2: new full-speed USB device number 5 using dwc_otg
                                  [   23.664674] usb 1-1.2: New USB device found, idVendor=0e8f, idProduct=0003
                                  [   23.664686] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber        =0
                                  [   23.664692] usb 1-1.2: Product: PLAYSTATION(R)3 Controller
                                  [   23.664695] usb 1-1.2: Manufacturer: Sony
                                  [   23.752901] input: Sony PLAYSTATION(R)3 Controller as /devices/platform/soc/3        f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:0E8F:0003.0002/input/input3
                                  [   23.753659] pantherlord 0003:0E8F:0003.0002: input,hidraw1: USB HID v1.10 Joy        stick [Sony PLAYSTATION(R)3 Controller] on usb-3f980000.usb-1.2/input0
                                  [   23.762980] usb 1-1.1.3: new high-speed USB device number 6 using dwc_otg
                                  [   23.892564] usb 1-1.1.3: New USB device found, idVendor=090c, idProduct=1000
                                  [   23.892577] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumb        er=3
                                  [   23.892581] usb 1-1.1.3: Product: Flash Drive FIT
                                  [   23.892585] usb 1-1.1.3: Manufacturer: Samsung
                                  [   23.892589] usb 1-1.1.3: SerialNumber: 0378718120002178
                                  [   23.893338] usb-storage 1-1.1.3:1.0: USB Mass Storage device detected
                                  [   23.894381] scsi host0: usb-storage 1-1.1.3:1.0
                                  [   23.939240] usbcore: registered new interface driver uas
                                  [   24.191598] usb 1-1.1.1: new high-speed USB device number 7 using dwc_otg
                                  [   24.322730] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800
                                  [   24.322761] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumb        er=0
                                  [   24.592705] libphy: lan78xx-mdiobus: probed
                                  [   24.608812] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb        period 64
                                  [   24.714057] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
                                  [   25.402673] scsi 0:0:0:0: Direct-Access     Samsung  Flash Drive FIT  1100 PQ        : 0 ANSI: 6
                                  [   25.405848] sd 0:0:0:0: [sda] 501253132 512-byte logical blocks: (257 GB/239        GiB)
                                  [   25.405987] sd 0:0:0:0: [sda] Write Protect is off
                                  [   25.405993] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
                                  [   25.406130] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, does        n't support DPO or FUA
                                  [   25.417146] sd 0:0:0:0: Attached scsi generic sg0 type 0
                                  [   25.956236] random: crng init done
                                  [   25.956270] random: 7 urandom warning(s) missed due to ratelimiting
                                  [   27.251307]  sda: sda1
                                  [   27.255590] sd 0:0:0:0: [sda] Attached SCSI removable disk
                                  Once again sorry for the stream of info.
                                  I will try the echo "noop" > /sys/block/sda/queue/scheduler and see what that does. Does it matter where in the rc.local it goes or just at the end is fine?
                                  • EfriimE
                                    Efriim @ZioDarkmage
                                    @ZioDarkmage
                                    Above the last line.
                                    ZioDarkmageZ 1 Reply Last reply Reply Quote 0
                                    • ZioDarkmageZ
                                      ZioDarkmage @Efriim
                                      @Efriim
                                      Sorry just saw you question regarding vram and gpu. Everything is stock as image load for 4.4 except i upped ram in emulationstation from 80mb to 160mb.
                                      • EfriimE
                                        Efriim @ZioDarkmage
                                        @ZioDarkmage looks nominal, you could cut your boot time in half.
                                        I'll try to review and compile the changes I made to my system as I have had the same one for a while now, I don't remember everything I did.
                                        Well you do have two console= in your kernel cmdline one of them is a serial terminal. It is probably not at all impactful.
                                        this is my boot time
                                        Startup finished in 1.241s (kernel) + 14.557s (userspace) = 15.799s
                                        I think that sdram overclock is very impactful.
                                        and possibly raspi-config >> boot options >> wait for network on boot >> no
                                        I do not know how to run this update correctly however. If you use RetroPie Setup and do the Update and hit yes and yes, this will update your kernel firmware modules which may solve a problem with the usb. It is worth it, the update goes on to update all emulators from like source or something bizarre and immensely time consuming but you can interrupt it with ctrl+c. If it is interrupted you can just go to that emulator and update it or clear the source folder if you want.
                                        • HalvhjearneH
                                          @ZioDarkmage
                                          it all sounds good to me, so maybe its a problem with your pi.
                                          do you have another pi to test if the same problem occurs?
                                          you could also try with a diffrent usb stick and see if the same happends, but tbh it sounds weird.
                                          i also just remembered that case you use, maybe you can try it without the case connected and see if that makes a diffrence.
                                          • EfriimE
                                            Efriim @Halvhjearne
                                            @Halvhjearne
                                            I use the same case and pi, but I have a different flash drive...
                                            ! Oh I just thought of something, you can try formatting the usb drive with a different block size. 4096b to 16kb should be good, but I don't remember what is optimum, I guess it varies with the disk and larger flash sometimes use larger allocation units. And what you are using it for if it has small files to read like text.
                                            I have had sdcards that do not work to run programs with the allocation unit being too high. Because if it is grabbing a small file e.g. under 16kb then it will grab a part of the next file and fragmentation occurs, this is typically avoidable because the allocation table will not allow it but different flash medias will have different layouts. The same can apply to large files too, but I don't understand how, I think it has to do with the flash media technology then.
                                            EXT4 has a cool Block/Inode allocation policy. You may notice if you ever used an actual disk that it will delay writes until it decides where to allocate on the disk eliminating most fragmentation along with dynamic block allocation.
