Problem in nes mini theme
Hello everyone
I have a problem with the theme nes mini on pi0
the theme looks bad and zooms in at a resolution of 1280-1080 pal format
if instead I set it on 720 it is excellent but the screen gets smaller
blob:https://pasteboard.co/75179265-324b-4148-b7fb-35442a5fd4eb
@trusto481 Your image link is not working. The NES mini supported resolutions seem to be there ones, so if your resolution is not there, the theme might not look correctly.
@mitu thanks
There is the bad problem
https://pasteboard.co/GZC1u4O.jpg -
@trusto481 What resolution do you have exactly ? It doesn't look like 1280x1080 to me.
I have the resolution to 1280 pal the problem and that if I choose another the screen gets small and I only see the central theme but I see it well my tv and hd not full hd
I forgot to mention that the raspberry pi0 5: 3 format is set as the resolution
if instead I set it in 4: 3 or 16: 9 image I always see it as a zoom type -
@trusto481 said in Problem in nes mini theme:
Can you put it in pixels ? Haven't heard about 1280 pal resolution. Anyway, check the link from my first post to see what the NES mini theme supports as far as resolutions are concerned and find one that fits you, then modify the
layout.xml
file in the theme folder accordingly. -
would you be so kind as to tell me how it's done? with the pc hardly the cable
can you tell me how to do it please? to modify I can use the notepad ++ program ?? -
@trusto481 Copy the theme from the system folder to your own folder from the command line, exiting Emulationstation first:
mkdir -p $HOME/.emulationstation/themes cp -a /etc/emulationstation/themes/nes-mini $HOME/.emulationstation/themes
then you can edit the file in the theme folder over file shares from your PC, by opening the
\\retropie\configs\all\emulationstation\themes\nes-mini
folder and editing the file I mentioned. -
but look for this input you have to write in the text to install my resolution or just add this command I can solve my problem ??
To enter this command I must exit a Mule Shaun stationCan you explain it to me in plain language?
is there a video tutorial? -
You have to edit the file (
layout.xml
) to change the resolution of the theme. The commands will just create a copy of the theme in a place where you'll be able to edit the file.
So you need to- Exit Emulationstation by using it's menu (press
Start
and use theQuit
menu) or pressing F4 on the keyboard - Execute the commands using your keyboard.
- Open the file (
layout.xml
) in Notepad++ and edit it to change the resolution. This part you can do it over File shares, from your PC. You can find the file at the location I mentioned.
If you can't follow these directions, I'm afraid I can't be clearer that this.
I'll give you some good news, I solved by changing the resolution in 1920 to the resolution of 1920 and magicamante all resolved thanks a lot ...
we can also close the post
problem solved -
I don't quite understand - you changed 1920 to 1920 ? Did you manage to edit the file or you changed the TV's resolution ?
I solved by changing only the resolution with the one on the read me that you showed me ...
the problem was that I had set the resolution not compatible with that of the theme
