    Pi3 plus vga666 outputting 640x480 31k help
    vga666
    2 Posts 2 Posters 475 Views
      JordanJ
      Hey guys
      I'm running emulation station/retroarch (Colton downs vertical revision) and I'm trying to output through the gert vga666 in 640x480 in 31khz to an arcade monitor and I was just wondering which values would be required? I'll post my config shortly, but any help would be greatly appreciated
      BTW disable SPI and IC2
      heres my config
       # http://rpf.io/configtxt
       #hdmi_safe=1
       disable_overscan=1
       #overscan_left=16
       #overscan_right=16
       #overscan_top=16
       #overscan_bottom=16
       # overscan.
       #framebuffer_width=1280
       #framebuffer_height=720
       #hdmi_force_hotplug=1
       #config_hdmi_boost=6
       #hdmi_ignore_edid=0xa5000080
       #hdmi_group=2
       #hdmi_mode=4
       #this was added to force vga note 640x480 60hz
       dtoverlay=vga666
       enable_dpi_lcd=1
       display_default_lcd=1
       dpi_group=2
       dpi_mode=4
       #hdmi_drive=2
       # no display
       #config_hdmi_boost=4
       # uncomment for composite PAL
       #sdtv_mode=2
       #arm_freq=800
       dtparam=i2c_arm=off
       #dtparam=i2s=on
       dtparam=spi=off
       # Uncomment this to enable the lirc-rpi module
       #dtoverlay=lirc-rpi
       dtparam=audio=on
       gpu_mem_256=128
       gpu_mem_512=256
       gpu_mem_1024=256
       overscan_scale=1
       # Pretends no audio formats are supported by HDMI display, forcing all sound out the 3.5mm headphone jack.
       # May not be needed for all HDMI devices
       #this was turned on to enable the 3.5 audio jack
       hdmi_ignore_edid_audio=1
        You don't seem to run RetroPie, so why post here in the forums ? You can find the list of resolutions you can add in config.txt here.
