    nespi case yellow light bolt
    nespi case
    22 Posts 6 Posters 5.5k Views
      mitu Global Moderator @shavecat
      @shavecat said in nespi case yellow light bolt:
      everything works fine before with the old case..
      In this case, I think the answer is obvious. As I said, it's a simple test you can do to see if the case is at fault - remove the PI from the case and try to see if you get the under-voltage sign. If you still get it, then it's the case, not the power supply.
      shavecatS 1 Reply Last reply Reply Quote 0
      • shavecatS
        shavecat @mitu
        Yep , So i get it only when i plug in the usb harddrive .
        • GoldManSex778G
          GoldManSex778 @shavecat
          @shavecat are "u having also harddrive usb to it ?" I don't keep one connected to it but it will run one without power issues.
          "are u saying i need to connect the hard drive itself to the raspberry pi itself inside the case" - I wouldn't recommend doing that for heat reasons if it is even possible, I am using a thumb drive and it barely fits.
          "not with the usb the have in the case itself ???" I run the thumb drive off the internal usb. I only use the external usb ports for keyboard mouse and gamepads, but it does power a usb drive without lightening bolts.
          "and if so i will have to make a hole and fix the case by my self ???" - No definitely not, there is no need to cut any holes. The easiest thing to do would be examine the wiring on the usb hub on the nespi case, you can either fix the existing wire with a soldering iron or just replace the wiring all together. Honestly the best solution may be to just take out the nespi's usb hub and wire a direct usb extention to the raspberry pi's usb connectors; that is what I have been planning on doing to mine since the usb hub is just a liability and it would make more room inside.
          "So i need to give up on the case ??" - Not at all! it is a great case, looks just like an OG NES and has plenty of room for goodies inside. I knew the wiring was a problem when I bought mine but I was planning to customize it anyway. For the price it is pretty good, but it is fair to expect the wiring to be adequate.
          • shavecatS
            shavecat @GoldManSex778
            @GoldManSex778
            Thanks alot ,
            will give it a try when the power supply will come.
            • EfriimE
              Efriim
              I'm going to buy a new powersupply, to upgrade from the aftermarket 5V 2.5A, and hopefully alleviate the low voltage while charging a controller.
              Maybe I can recycle my old Power supply, it works for other models, I don't know what else.
              I'll share the results when I get the new one.
              Question though. I have a different model case, the megadrive case. How do I get the fan inside to stop being so noisy? It is like it is being pressed down on, and I've tried loosening the screws. Is there any tip or trick one could advise?
              • quicksilverQ
                quicksilver @Efriim
                @Efriim small fans are inherently noisy best thing you can do is get something that controls when the fan turns on. Something like this for example https://mini-mods.com/2018/12/29/setup-your-retroflag-megapi-case-with-fan-control-board/
                • EfriimE
                  Efriim @quicksilver
                  @quicksilver
                  It isn't its normal function, something presses down on it and it rattles. If I shake it a little bit sometimes it will set right.
                  I do like that fan controller though. It would be able to shutdown the fan on OS poweroff.
                  Oh yes, and an obligatory, always remember to remove the sdcard when disassembling and assembling a case.
                  • quicksilverQ
                    quicksilver @Efriim
                    @Efriim does it make the same noise if the case is left open? Or just when you screw it back together? Maybe you need a thinner fan.
                    • EfriimE
                      Efriim @quicksilver
                      @quicksilver
                      When I screw it back together! I think it does it if the fan screws are too tight also. More like a whine, yeah it's too tight.
                      ...It was too loose, I tightened the screws, they turn hard and their long so its difficult to judge how in they are. Only needed to mess with it some more.
                      It will probably start doing it again, sort of why I gave up to avoid being frustrated with it.
                      • shavecatS
                        shavecat
                        Did fix the pro' the power 2.5amp original
