    Removed emulationstation-dev help
    emulationstatondevpackages
    3 Posts 2 Posters 488 Views
    • paffleyP
      paffley
      Hi guys, I removed emulationstation-dev from experimental packages and now ES wont load after reboot, do I need to re-install anything from retropie-setup?
        mitu Global Moderator @paffley
        @paffley Just install Emulationstation (the regular package) from the core packages section.
        paffleyP 1 Reply Last reply Reply Quote 0
        • paffleyP
          paffley @mitu
          @mitu said in Removed emulationstation-dev help:
          Thanks @mitu
          I installed a fresh ES from binary then had to re-add es_systems.cfg content from an old backup I had (modified).
          All working now thank you! keep up the super work!
