    Nespi case (Not the PLUS +) 2 Question
    nespi case
    22 Posts 8 Posters 3.2k Views
    • shavecatS
      shavecat
      Hey,
      So i have the nespi case - but i didnt not notice theres a plus to that .
      So i dont have anyway to use the buttons in a safe way ? ( beside in the emulator rest )
      i got to have the plus (+)for that function ?
      2-
      what fans do u guys use ? the only one that come with it ? or more fans on the pi itself ? with the old case it was like 42 deg' max 46 deg'(when playing)now with the nespi case its always 50/52 deg' even go around 60 /64 deg' when playing games and i dont really like it ...)
      Thanks a lot (hope its not off topic).
      GoldManSex778G quicksilverQ EfriimE caver01C 4 Replies Last reply Reply Quote 0
      • GoldManSex778G
        GoldManSex778 @shavecat
        @shavecat said in Nespi case (Not the PLUS +) 2 Question:
        Yes, But I honestly don't see the point to that feature. I will admit it is kinda cool on paper, but I never ever used mine, and don't even have the script installed on this build because I just never used it.
        As far as a fan goes I put a 60mm Noctua that I had to customize the case to fit. The 30mm fans are notoriously loud but anything with a 5v range should work. But as you observed the NESpi case gets very warm, it is basically a big wool blanket around your pi.
        • quicksilverQ
          quicksilver @shavecat
          @shavecat your pi is just fine at those temperatures. You would have to raise the temperature above 80-85c before you would even need to start worrying about your pi being damaged and even then the pi is programed to throttle the CPU to prevent it from overheating long before then. So really the only thing to really consider is throttling affecting your performance. If youre not throttling then you're fine.
          • EfriimE
            Efriim @shavecat
            @shavecat
            the nespi+ case advertises a safe shutdown, but I don't know what is different about the non plus model. I guess that the switch really does cut the power. Technically a script could be written to perform safe shutdown on the gpio shim or whichever, if it were possible to rewire the switch onto the gpio, but then the switch would need to be disconnected and something to pass the relay would need to be replaced.
            Make sure the fan is blowing outwards, I installed mine upside down the first time.
            There is only one vent so air will blow out of it regardless, but having it upside down helps none.
            GoldManSex778G 1 Reply Last reply Reply Quote 0
            • shavecatS
              shavecat
              okay Thanks everyone :)
                Silent
                It seems like this shop is selling upgrades to a non-plus nespi case, adding this very feature:
                https://mini-mods.com/2017/12/01/setup-nespi-case/
                • GoldManSex778G
                  GoldManSex778 @Efriim
                  @Efriim You are right that the name "safe shutdown" is misleading, what that feature does is add more "functionality" to the reset button mainly, for instance pressing the reset button while in a game will reset the emulator instead of the whole system, or exit to emulationstation.
                  • caver01C
                    caver01 @shavecat
                    You do have options if you are willing to tinker with wires, solder etc. I think the first documented success was written up here:
                    https://retropie.org.uk/forum/topic/12424/retroflag-nespi-case-soft-power-reset-hack
                    which links to a nice tutorial doc and lots of discussion. I did something similar and I also use a mausberry circuit. Solutions involve modifying the button board by cutting the traces to isolate the switches, then running wires you solder to the switches to GPIO pins.
                      cyperghost @caver01
                      @caver01 Yes there were indeed some nice mods prepared at this time. But all in all you would pay the same money for a NESPi+ housing rather to get those few electronic parts ;)
                      At this time I rebuild the whole PCB and used a Mausberry for the "Yet annother NESPi case" mockup ;)
                      @GoldManSex778 No the "safe shutdown" is needed to obtain proper metadata if you leave emulationstation. Other things you talk like reseting the emulators were initatied by @meleu because users saw a demand for this. You can read the glory story from here.
                      • EfriimE
                        Efriim @cyperghost
                        @cyperghost
                        Safe Shutdown, was a reference to the nespi case which opposedly cuts the power unlike the more advertised nespi+
                          cyperghost @Efriim
                          @Efriim Got you. Yes the non-plus version were just two switches (a momentary and a latching one) put in series. And every action done by these resulted in an immediate power cut. I think it is better at this time to buy a NESPi+ case before tinker with wires and solder iron. Imho the MegaDrive and the SuperPi outstand both NES housings.
                          I use an old unmodified NESPi case (nonplus) just as small headless media/ftp/mail server. So there is no real need for proper shutdowns.
                          • shavecatS
                            shavecat
                            So as i experience in the Nespi case,
                            its really closed up so i did a few holes where the fan go up to take the air outside...
                            really helps.
                            I have some idea i wanna put two fans on the pi as i see on the pic'
                            so the nespicase take
                            can i put another fan form the pi itself ?
                            ON Pin#02 And Pin#09 .
                            Will it harm the pi with the nespicase ?
                            Or maybe just connect them all to the same wires and let the split the power between them??(where the nespicase tell u to connect the fan )
                            (I Wanna add the dualfan on the pi itslef , and another one on the case to get the air flow out)
                            caver01C EfriimE 2 Replies Last reply Reply Quote 0
                            • caver01C
                              caver01 @shavecat
                              @shavecat I expect current draw would be your limiting factor with multiple fans, but I don’t know how quickly it becomes an issue. You could certainly use 5v and GND pins. I changed my fan over to a 3.3v pin to reduce the noise. A fast fan can get pretty loud. Why do you think you need so many fans?
                              • EfriimE
                                Efriim @shavecat
                                @shavecat
                                I have read not to connect the fans directly to the gpio as this could damage the pi, instead you will want to use the fan controller as seen here
                                https://youtu.be/ AP09tmNax18?t=274 (without the space)
                                at 4:34
                                whether it is enough to power two fans, I do not know.
                                • quicksilverQ
                                  quicksilver
                                  I agree with @caver01, you don't need multiple fans. A decent heatsink and case fan is all you need. Anything more than that is likely to make more noise and draw more power with no added benefit. My pi 3b+ is overclocked and heatsink/case fan is all I have ever needed.
                                  • shavecatS
                                    shavecat
                                    Lovely okay thanks all :)
                                    It was still around 60 even went to 70deg'.
                                    At the end what i did beside put the heat stink inside and the double fans-
                                    Did a small hole where the fan for the air outside was need to be and add big fan on it to get the warm air out -
                                    now i get max 52 deg' most ,(after more then few hours gaming)
                                    when i run kodi im getting less then 40-
                                      RetroSavior
                                      i'd just switch to thr plus anyways. not for the safe rest/shutdown. But for the brtter voltage. Ive built some for friends and lept getting low voltage warnings on them all the time. didnt matter which cable i used. Switching to the plus version
                                      , no more undervoltage warnings
                                      shavecatS 1 Reply Last reply Reply Quote 1
                                      • shavecatS
                                        shavecat @RetroSavior
                                        @RetroSavior
                                        i also getting the high voltage but really really not as many times as the start...
                                        just once a well (Usually more when its really getting hot/warm) so im not sure its the plus helps....
                                        check the temp' and if u really using the raspberry power adapter also helps.
                                        • GoldManSex778G
                                          @shavecat That is one cool pi (pun intended) Just keep your cat away from that fan, he might want to puke on it lol.
                                          shavecatS 1 Reply Last reply Reply Quote 0
                                          • shavecatS
                                            shavecat @GoldManSex778
                                            @GoldManSex778
                                            haha yeha i put something on the fan this time ;) thanks
