    Aimtrak Installation Issue
    aimtrakpythonoptional packag
    47 Posts 6 Posters 10.8k Views
      Garavar
      On the latest version of Emulationstation and Retropie. Installed Optional Package for Aimtrak light gun, it installed without a problem.
      I go to Options select newly installed "Gunconf" and it shows my gun detected. Tells me to press trigger and it says "Gun Detected. Loading Configuration..." then nothing happens.
      I select Quit and this error pops up. Can't figure out what I did wrong. ThanksIMG_20190411_2107088-1.jpg
        I don't think RetroPie has such package - you're probably using a 3rd party image, in which case you best contact the author of the image to ask for troubleshooting advice.
          grant2258 Banned
          https://github.com/gunpadawan/gunconf only reason i know this is ive been looking up how dolphin bar and aimtrack devices are working. I dont have these devices but ive put some code together to test if i ever get one. I need to check how and if ra maps them once i know how they are mapping in RA the code is trivial.
            Garavar @mitu
            @mitu said in Aimtrak Installation Issue:
            Sorry I wasn't specific. The instructions for Gunconf has you install optional package mame 1.4 and the Gunconf script which all worked. But then I get that error and I don't know what it means "python" etc.
            EfriimE mituM 2 Replies Last reply Reply Quote 0
            • EfriimE
              Efriim @Garavar
              @Garavar
              I don't know, perhaps a reset, or reinstallation.
              https://github.com/gunpadawan/gunconf#prerequisites
                mitu Global Moderator @Garavar
                @Garavar Python is the scripting language which is used by the calibration script, the error is specific to the script - so I don't think you did something wrong. How are you running the script ?
                  Garavar @mitu
                  I followed the directions from site (below). They all worked except sudo cp utils/aimtrak.rules /etc/udev/rules.d/99-aimtrak.rules which did nothing and sudo udevadm control --reload-rules which said "no directory found"
                  Directions followed...
                  sudo apt install apt-transport-https python-dev python-pygame python-setuptools
                  Get the source
                  git clone https://github.com/gunpadawan/gunconf
                  Install python module
                  cd gunconf
                  sudo python setup.py install
                  Udev rules
                  Application requires access to the aimtrak usb device. It is usually necessary to configure udev to let your specific user access that device.
                  To let any user access the device, do:
                  Launch
                  To launch application, you can execute utils/gunconf.sh
                  When I get here, it launches application, detects gun but does nothing else. When I exit I get those errors.
                  • EfriimE
                    Efriim @Garavar
                    @Garavar
                    You should have this file in the gunconf/utils/ subfolder:
                    https://github.com/gunpadawan/gunconf/blob/master/utils/aimtrak.rules
                    and it needs to go here "/etc/udev/rules.d/99-aimtrak.rules"
                    sudo mkdir -p /etc/udev/rules.d
                    cd
                    cd gunconf/utils
                    sudo cp aimtrak.rules /etc/udev/rules.d/99-aimtrak.rules
                    G 2 Replies Last reply Reply Quote 0
                      @Garavar said in Aimtrak Installation Issue:
                      That's not needed, if the gun is detected as a mouse, the running user should be able to access the mouse device.
                      • EfriimE
                        Efriim @mitu
                        but it also has a specific vendor id that is not registered anywhere else
                        SUBSYSTEMS=="usb", ATTRS{idVendor}=="d209", MODE="0666"
                          grant2258 Banned
                          it can be detected as a mouse or joystick or both the wiimote does the same thing you only need that is you are using the joystick. I dug my old wii mote out a and set it up seems to be working ok ill need to get a sensor bar for it at some point to test the ir though
                            Garavar @Efriim
                            @Efriim said in Aimtrak Installation Issue:
                            @Garavar
                            cd
                            cd gunconf/utils
                            I cant even find my gunconf/utils/ folder...is there a permission I am missing?
                            • EfriimE
                              Efriim @Garavar
                              @Garavar
                              it should be in the directory where you cloned the github for gunconf.
                              maybe
                              cd ~/gunconf/
                                Garavar @Efriim
                                @Garavar
                                cd
                                cd gunconf/utils
                                Tried this, still gets stuck on configuration and went I quit I get the same index error from photo ;(
                                mituM G 2 Replies Last reply Reply Quote 0
                                  @Garavar Do you have more than one mouse device connected ? You didn't gave much details about your actual system - maybe the configuration utility incorrectly chooses you mouse device.
                                  Can you run cat /proc/bus/input/devices with the gun connected and post the output here ?
                                    Garavar @Garavar
                                    @Garavar
                                    cd
                                    cd gunconf/utils
                                    I think I figured out the problem but don't know how to fix it. When I go to file manager all the folders and files are there (utils, pgu) but the Gunconf folder with drivers and files like conversion.py aren't there. Don't know why.
                                    I followed the download steps it should be there.
                                      grant2258 Banned
                                      make sure you are using python 2.x and not 3
                                      try running with gunconf/utils/gunconf_w_logs.sh aand post the log
                                      also post a
                                      sudo udevadm test -a add $(udevadm info -q path -n /dev/input/js0 )
                                      replace path with relevant joystick and mice
                                        Garavar @grant2258
                                        @grant2258 said in Aimtrak Installation Issue:
                                        also post a
                                        Error log phot attached, I also tried reinstalling and got similar errorIMG_20190414_1040029.jpg
                                          grant2258 Banned
                                          any more information in ~/.gunconf.log ?
                                            a1084426
                                            Hi
                                            I have exactly the same issue. The gun works ok as I cheated and calibrated it on a windows laptop on the same external screen so it sorta works but id still like to know why I detects the Gun but never proceeds past into the following screen for calibration
