    Gamepadblock Firmware help
    gamepadblock
    3 Posts 2 Posters 539 Views
      srm51555
      Hello,
      I recently received my gamepadblock and i'm having trouble updating the firmware. Windows does recognize the device but when I download the "windows-amd64" option and run it the command prompt will be on the screen for a second and then close. I went into the command prompt in windows and typed in ./petrockutil and received an error as it not being a recognized command. The end project will be retro pi on a raspberry pi 2 . Thanks for your help.
      Thanks,
      Scott
        srm51555 @srm51555
        @srm51555
        I eventually got this to work with using a different computer.
        Thanks,
        Scott
          petrockblog Global Moderator
          Glad to hear that you made it work!
