    DOSBox - Keyboard mapping issue - works while outside emulationstation, all wrong keys while in ES
    dosboxkey mappingkey bindings
    3 Posts 2 Posters 849 Views
      doubleeuroz
      I originally had Lr-Dosbox installed and I think that its possible Retroarch messed up the configuration for ES.
      Now, only Dosbox is installed. When start dosbox inside emulation station, they keys are all mapped wrong.
      instead of "asdf" it types "uiop"
      Delete key types 5 and qwer types 7890
      I am using the same .conf file each time and yet somehow it only does this when launching from inside ES.
      Here is the first part of the .conf
      fullscreen=false
      fulldouble=false
      fullresolution=original
      windowresolution=original
      output=surface
      autolock=true
      sensitivity=100
      waitonerror=true
      priority=higher,normal
      mapperfile=mapper-SVN.map
      usescancodes=true
      the mapper-SVN.map file is in the normal place.
      Any ideas on why this works at the command line or in Pixel desktop but doesnt work when launched in ES?
        dudleydes @doubleeuroz
        @doubleeuroz Set usescancodesto false.
        Any reason why it's set to true? The DOSBox scriptmodule sets it to false.
          doubleeuroz
          I tried both values for the usescancodes and both failed.
          However, i was able to finally make it work by setting the Keyboard type to us instead of auto.
          I dont know why this would break based on if it is run from inside ES vs command line. My locale is set right.
