    DOSBox Emulator Not Showing Up
    dosbox
    27 Posts 5 Posters 4.4k Views
      edmaul69 @mitu
      @mitu i use a custom es_system.cfg in the config folder now. The first time it appeared in the config folder it created it on its own after an update. Others have had that happen too.
      • EfriimE
        Efriim
        here is a copy of my es_systems.cfg,
        it is missing only a few systems
        https://drive.google.com/open?id=1xOLlgKd_mQ_WgPeE8d1VQW5wo8PYrexM
        You can copy it to /opt/retropie/configs/all/emulationstation/es_systems.cfg
        or you can delete this file and it will use the default es_systems.cfg that is configured automatically.
        You can also find this file in samba share
        \\retropie\configs\all\emulationstation\es_systems.cfg
          mitu Global Moderator @edmaul69
          @edmaul69 said in DOSBox Emulator Not Showing Up:
          That's not the point. It's perfectly fine to customize the configuration file, as long as you're aware of the implications. But there's no way an update would create the file by itself - it's always created manually.
          EfriimE edmaul69E 2 Replies Last reply Reply Quote 0
          • EfriimE
            Efriim @mitu
            @mitu I've had systems not show up out of the box. But anyways, it doesn't look like a very configured es_systems and its absolutely right that there is no Dos/PC system.
            I guess it is possible that I edited the es_systems.cfg, it was really early on, if the main config has been edited, will it not be updated anymore when installing a new system?
              edmaul69 @mitu
              @mitu i had that happen with an update. This was a few years after i was using the pi. So i was familiar enough with it. And others who said the same thing had the same issue. Also an update once changed all the rom folders locations in es_systems.cfg from /home/pi/ to /root/
                I also had that happen to me - because instead of using sudo, I was logged on as the root user. I bet it still happens if you're doing sudo su and run the update.
                  mitu Global Moderator @Efriim
                  @Efriim said in DOSBox Emulator Not Showing Up:
                  https://retropie.org.uk/docs/EmulationStation/#es_systemscfg-edits
