    Which rom sets for FBA?
    fba
    7 Posts 4 Posters 3.7k Views
      tony77
      Hello everyone,
      I've been using MAME for a long time now, but a few games don't work right - notably Star Wars and Battlezone. It was suggested that these might work better in FBA. I'd like to try it, but I can't figure out what ROM versions I need to make it run.https://www.7zip.vip/
      MAME is very sensitive to having the ROM files matching the version of the emulator, and there's quite a bit of documentation out there describing what ROM sets go with which emulator versions. My understanding is that FBA has a similar requirement, but I can't find any documentation about what version of FBA retropie is currently using, or what ROM set version needs to go with that. https://scrabblewordfinder.vip/ https://www.applock.ooo/
      Thank you!
        dankcushions Global Moderator
        same answer as you received on reddit :) https://www.reddit.com/r/RetroPie/comments/bdgb20/which_rom_sets_for_fba/
        ie https://github.com/RetroPie/RetroPie-Setup/wiki/FinalBurn-Alpha
          barbudreadmon
          @quicksilver Not sure you are the author of the comment on reddit, but fbalpha has support for vector games.
          quicksilverQ 1 Reply Last reply Reply Quote 1
          • quicksilverQ
            quicksilver @barbudreadmon
            @barbudreadmon I wasnt sure if it did or not. Thanks for the clarification. One question, does it offer the same tools for tweaking flicker, beam width etc?
              barbudreadmon @quicksilver
              @quicksilver said in Which rom sets for FBA?:
              Nope, i didn't know mame had that feature, i just added basic resolution upscaling in core options (a dips called Hi-res mode).
              • quicksilverQ
                @barbudreadmon I think mame2003+ did a lot of recent work to get vector game quality on par with advmame. Advmame used to be my go to because it looked so much better but mame2003+ looks the same to me now so I switched to it for the convenience of Retroarch.
                  @quicksilver ok, maybe i'll take a look in the future when things settle down in my TODO list.
