    [SOFT] ARRM : Another Gamelist, Roms manager, and Scraper for Recalbox, Batocera, Retropie
    gamelistscrapersoftware
    250 Posts 24 Posters 160.1k Views
    • nexusone13N
      nexusone13 @ZzackK
      @ZzackK
      Select options you want in 'Scrape Options',
      Select the roms you want
      then click on 'Check Roms'
      If you leave your mouse over each button, you'll see a tooltip that explains the feature
      ARRM (Roms Manager, Scraper for Recalbox, Batocera, Retropie, ES...) : http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
      Wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=start-en
      Discord: https://discord.gg/p7QsBTS
      • Z
        ZzackK @nexusone13
        @nexusone13 thx
        Is too many options for beginning :)
        ExarKunIvE 1 Reply Last reply Reply Quote 1
        • ExarKunIvE
          ExarKunIv @ZzackK
          @ZzackK yes all the options are over whelming but it is so worth it with how powerful this tool is.
          It is the only one I use now.
          Also with how responsive @nexusone13 is. Is such a big help and he is always updating it to make it even better
          nexusone13N 1 Reply Last reply Reply Quote 2
          • nexusone13N
            nexusone13 @ExarKunIv
            Thank you so much @ExarKunIv for your comment
            • Z
              ZzackK
              file "SecondSamurai_v1.3a_AGA_1624.lha" with "activete cache" crash ARRM ;)
              Works but needed rechecking option.
              • Z
                ZzackK
                Powerful tool! Now Amiga and PC-Dos are easy :)
                ps
                Please add AmigaCD.
                ps2
                And add support emumovies.
                nexusone13N 1 Reply Last reply Reply Quote 0
                • nexusone13N
                  nexusone13 @ZzackK
                  Hi @ZzackK
                  You can adapt the ARRM configuration files to take your systems into account.
                  Follow the wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=different_systems_name_en
                  • Z
                    ZzackK
                    I cant add few games to collection. I try do it like in tutorial video and select few but in file is only one.
                    nexusone13N 2 Replies Last reply Reply Quote 0
                    • nexusone13N
                      nexusone13 @ZzackK
                      Hi @ZzackK
                      your right, I need to fix that
                      • nexusone13N
                        nexusone13 @ZzackK
                        @ZzackK
                        Fixed in the last 1914 Beta 6
                        Changelog : http://jujuvincebros.fr/wiki/arrm/doku.php?id=changelog-en
                        Download Beta link : http://jujuvincebros.fr/telechargements2/category/11-arrm-update-correctif
                        !! You must have at least 1.9.1.3 version installed !!
                        Copy this files over your existing files.
                        Z 1 Reply Last reply Reply Quote 1
                        • Z
                          ZzackK @nexusone13
                          @nexusone13
                          thx :)
                          • Z
                            ZzackK
                            Is Arrm support 5 threads accounts in Screenscraper?
                            • nexusone13N
                              nexusone13 @ZzackK
                              @ZzackK no, sorry, ARRM is mono thread
                              • nexusone13N
                                nexusone13 @nexusone13
                                Hi everyone,
                                A new version of ARRM is available:
                                			*  WARNING  *
                                Since ARRM 1.9.1.4 Beta 1 , ARRM can run in 64-bit mode.
                                It is necessary to change the database engine by installing the file accessdatabaseengine_2016_x64.exe
                                (or its 32-bit equivalent: accessdatabaseengine_2016_x86.exe )
                                which you will find here : https://www.microsoft.com/en-us/download/details.aspx?id=54920
                                1.9.1.5 (06/07/2022)
                                • Added: Template download module accessible via the 'Show Mix Model' button. (In order to lighten the installation files) Wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=choose_mix_en#download_and_install_new_mix_templates
                                • Added: Execution of ARRM in 64 Bits on a compatible system otherwise in 32 Bits (update the database engine. read above) See wiki: http://jujuvincebros.fr/wiki/arrm/doku. php?id=download-fr#installation
                                • Added: 'Custom Marquee' checkbox in the 'Images Options' panel, allows you to create custom marquee via the 'marquee_fanart 1280_v2(Marquee)' template This marquee is made up of the upper portion of the game's fanart on which the Wheel/ logo. Masks can be used. (request by Bob Morane) See Wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=custom_marquee_en
                                • Added: 'Artworks' checkbox in the 'Rom informations' panel which allows, if checked, to delete the links to the artworks/images during the execution of the procedure 'Delete Metadata' Wiki: http://jujuvincebros.fr /wiki/arrm/doku.php?id=delete_metadata_en
                                • Added: keyboard shortcuts to navigate in the datagridview (database). Click on the "Shortcut" link for a list of shortcuts. (request by Unktehila) See wiki: http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=interface-en#the_database_list_of_roms_3
                                • Added: The Delete key allows you to delete the selected elements in the database (request by Unktehila)
                                • Added: It is possible to dock the database via the closing X (request by Unktehila)
                                • Added: Multi_part.txt file used in the duplicate detection procedure and when creating M3Us in mass (this file is located in %appdata%\Nexouille Soft\arrm\database\multi_part.txt) Wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=search-en
                                • Added: Templates and Templates videos offered by TVsIan (Ian Murray) compatible from version 1.9.1.3 available here: http://jujuvincebros.fr/telechargements2/category/8-templates-arrm
                                • Modification: Redesign of the 'Add to Collection' module
                                • Modification: The listview of available updated files (via the 'Update' tab) are sortable by date by clicking on the date column
                                • Modification: Update of the core/emulator files for Batocera and Recalbox used in the 'Set Core/Emu' procedure: http://jujuvincebros.fr/wiki/arrm/doku.php?id=emulator_core_en
                                • Modification: 'Add Disk', 'Add Country', 'Add Language' tries to conform to Tosec Naming Convention
                                • Modification: The 'add disk' checkbox now relies on the multi_part_add_disk.txt file (located in %appdata%\Nexouille Soft\arrm\database\multi_part_add_disk.txt) to find and retrieve multi-disk information in the names of files .
                                • Modification: The duplicate search no longer considers game files with disk 1/disk 2.../tape 1/tape 2... as duplicates. (uses the multi_part.txt file located in %appdata%\Nexouille Soft\arrm\database\multi_part.txt). Wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=search-en
                                • Fixed: ARRM 1.9.1.4 app was not launching for new ARRM users.
                                • Fixed: Depending on the templates, some screenshots were saved with black borders
                                • Fixed: 'Add to collection' was not working correctly. (bug report by ZzackK)
                                • Fixed: A crash occurred during a scrape, when box, marquee, cartridge were selected as default image.
                                • Fixed: Duplicate search on CRC32 and MD5 did not work properly.
                                Donwload links:
                                Full version via arrm_setup.exe (remember to uninstall the previous version): http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
                                Full version without using arrm_setup.exe. (Allows you to install or update the application by copying files): http://jujuvincebros.fr/telechargements2/category/12-arrm-executable-only
                                Patch page between two versions and Beta : http://jujuvincebros.fr/telechargements2/category/11-arrm-update-correctif
                                ARRM WIKI : http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=Start-en
                                Videos tutorial playlist : https://www.youtube.com/playlist?list=PLwA4JmSgv-PtLlzwPMOad5Ti96UfsbSzK
                                Textual Discord : https://discord.gg/p7QsBTS
                                Twitter : https://twitter.com/ARRM_sofware
                                Facebook : https://www.facebook.com/ARRMbyNexusone13
                                Utip : https://www.utip.io/jujuvincebros/arrmdonation
                                Buymeacoffee : https://www.buymeacoffee.com/ARRM
                                Patreon : https://www.patreon.com/arrm
                                Z 1 Reply Last reply Reply Quote 2
                                • Z
                                  ZzackK @nexusone13
                                  @nexusone13 thx
                                  • mituM mitu referenced this topic on
                                  • nexusone13N
                                    nexusone13 @ZzackK
                                    Hi everyone,
                                    		 WARNING
                                    It is necessary to change the database engine by installing the file accessdatabaseengine_2016_x64.exe (or its 32-bit equivalent: accessdatabaseengine_2016_x86.exe ) which you will find here : https://www.microsoft.com/en-us/download/details.aspx?id=54920
                                    See wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=download-en#installation
                                    1.9.1.6 (07/04/2022)
                                    • Added: 'The Bezel Project' button which automatically retrieves game bezels from The Bezel Project or locally and creates configuration files depending on the frontend used. See wiki: http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=bezels_project_en#the_bezel_project
                                    • Added: 'GamesDB manual' checkbox in the 'Scrape Options' tab: allows the manual to be retrieved from the gamesdatabase site, when the manual was not found during the scrape (regardless of the engine)
                                    • Added: Retrobat checkbox in the 'Recalbox/Batocera/Screenscraper' tab which allows you to adapt certain features for Retrobat
                                    • Added: Retrobat taken into account for collection creation. See Wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=add_collection_en
                                    • Added: Exodos references: When loading a blank DOS/PC gamelist, ARRM will search its database for game information (Title, description, developer, publisher, genre, year)
                                    • Added: A 32-bit version (arrm_32bits.exe) in the application directory, for those who encounter problems with the database engine when launching the application
                                    • Added: Desktop shortcuts for the 64bit version (Arrm.exe) and the 32bit version (Arrm_32bits.exe), as well as a link to the WIKI
                                    • Added: 'Add to collection' and 'Put in Cache' in the context menu of the Database
                                    • Modification : Change design of the 'Add Rom to collection' Module . See wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=add_collection_en
                                    • Modification: Configuration files to take into account new systems
                                    • Modification: Scummvm references: When loading a Scummvm gamelist, ARRM will search its database for game information (title, developer, genre, year)
                                    • Modification: New version of the database.
                                    • Fixed: Scraping on HFSDB could return incorrect results
                                    • Fixed: Crash on addition to collection.
                                    • Fixed: Since version 1915, fanarts were displayed in TVsIan Templates Screenshot only
                                    • Fixed: Various bugs
                                    Donwload links:
                                    Videos tutorial playlist : www.youtube.com/playlist?list=PLwA4JmSgv-PtLlzwPMOad5Ti96UfsbSzK
                                    Donations:
                                    • ExarKunIvE
                                      ExarKunIv @nexusone13
                                      @nexusone13 again amazing work, i cant wait to give this a go on my next build
                                      nexusone13N 1 Reply Last reply Reply Quote 1
                                      • nexusone13N
                                        thank you @ExarKunIv for your support
                                          sagaopc @nexusone13
                                          O have a problem...
                                          When try to scrap Pc games, ALL show hidden, and don't show in Rom list.
                                          I'm using retrobat and scrapping .lnk
                                          • nexusone13N
                                            nexusone13 @sagaopc
                                            Hi, sagaopc
                                            just check this checkbox (PC/DOS files mode) ;
                                            or remove the "windows" entry from the list of managed systems in folder mode by editing the file "systemes_as_folder.txt" by clicking on of this items :
                                            If you choose this second option you can leave unchecked the 'PC/DOS files mode' checkbox.
