    rom folder on network not mounted at start #network
    network sharenetwork
    15 Posts 2 Posters 1.1k Views
      Stargrove1
      I'd like to use the described method to store the roms (or the whole RetroPie folder) on my NAS. I followed the description "Running ROMs from a Network Share" and tried both solutions (autostart.sh and fstab). When I execute the command from autostart.sh manually over ssh, the roms are present. Same thing for the fstab entry, when calling sudo mount -a, all roms are available. But after doing the reboot, the folder does not get mounted in either methods. According to the forum entries, I tried adding sleep, changing the sequence, using several options but nothing worked.
      What else can be done to get the network connected?
        Can you check in raspi-config, under the Boot Options, if Wait for network is disabled or enabled ?
        Usually this kind of problem appear because the network is not ready when the mount command is executed - hence the advices to add a sleep if you're using the autostart.sh script.
          Stargrove1
          Yes this option is set, I did follow the guide https://retropie.org.uk/docs/Running-ROMs-from-a-Network-Share/ telling to activate it
            After you mount the driver - manually - do all your ROM folder appear correctly ?
            Can you post your entry from /etc/fstab ?
              Stargrove1
              I used a new image whithout roms installed, when mounting manually, I checked with ls /RetroPie/roms/amiga and I saw the roms from my network, no matter if autostart or fstab method
              fstab entry (copied and modified from the guide):
              //mynas/Multimedia/Spiele/Retropie/roms cifs username=xxx,password=xxx,nounix,noserverino,defaults,users,auto 0 0
                mitu Global Moderator @Stargrove1
                @Stargrove1 Are you sure it's the correct /etc/fstab entry ? You're missing the mountpoint (2nd position), which should be /home/pi/RetroPie/roms.
                  Stargrove1
                  Sorry, my mistake, it has to be:
                  //mynas/Multimedia/Spiele/Retropie/roms /home/pi/RetroPie/roms cifs username=xxx,password=xxx,nounix,noserverino,defaults,users,auto 0 0
                    Stargrove1
                    Entry in the autostart.sh is:
                    sudo mount -t cifs -o username=xxx,password=xxx,nounix,noserverino //mynas/Multimedia/Spiele/Retropie/roms /home/pi/RetroPie/roms
                      The /etc/fstab entry seems fine. Can you try adding x-systemd.automount to the mount options and reboot to see if it's auto-mounted on start ?
                        Stargrove1
                        When changing to
                        //mynas/Multimedia/Spiele/Retropie/roms /home/pi/RetroPie/roms cifs username=xxx,password=xxx,nounix,noserverino,defaults,users,auto,x-systemd.automount 0 0
                        no roms available, I tried to do sudo mount -a, the output is
                        /sbin/mount.cifs: invalid option -- 't'
                        Usage:  mount.cifs <remotetarget> <dir> -o <options>
                        Mount the remote target, specified as a UNC name, to a local directory.```
                          @Stargrove1 I don't get that error if I test with a local address. What version of RetroPie are you using (see https://retropie.org.uk/forum/topic/3/read-this-first) ?
                            Stargrove1 @mitu
                            Version states 4.4.11
                              Sorry, can't figure out why this doesn't work. Try looking in the dmesg output after the boot or adding a larger timeout before ES starts in autostart.sh.
                                Stargrove1
                                Thank you very much for the help, I will continue setting up the Retropie with local roms and try again with a spare Pi to get the network solution running.
                                  Stargrove1
                                  Today I tried again with a new reflashed image on my pi zero w, I just added Wifi and autostart.sh entry and it worked fine. Guess I will just start over with my pi 3 to get the actual system running from network.
                                  Thank you for your support
