    setting up a clone wireless ps3 controller with retropie
    ps3 controllers
    2 Posts 2 Posters 380 Views
      PCKid
      bought a presetup microsd card for my raspberry pi 3+. Controllers have since stopped connecting because my pc in the other room thought it was a keyboard and now the controller won't connect. Have gone through the wiki on how to reconnect but it says it has to do it in the emulation station. My problem is the presetup microsd doesn't stop at the emulation station but keeps going to retropie and then retroarch. i can get to retropie from the retroarch menu but not back to the emulation station. is there a way to either exit to the emulation station or interrupt the boot sequence before it goes to retropie?
        mitu Global Moderator @PCKid
        @PCKid It doesn't seem you have RetroPie installed, but Lakka (lakka.tv). Regardless, we don't support 3rd party images, so start by installing the image from retropie.org.uk/download and then you can follow the docs to set-up your controller and configure it in Emulationstation.
