    Emulationstation not remembering controller settings
    emultionstationretropiecontroller help
    12 Posts 3 Posters 445 Views
    • Honda Z50MH
      Honda Z50M
      I have an issue with Emulationstation not remembering controller settings, which I'm sure is cause by 'retropie' thinking there is no available memory.
      I set controller ok and can scroll through emulators and games ok BUT as soon as I choose a game controller or keyboard no longer work.
      Also if I go into Retropie setting and can scroll around settings ok but as soon as I exit back to the front end both controller and keyboard no longer work
      I then have to power cycle to reboot and start all over again.
      System info displayed m-sd card 116GB, 110GB used BUT 0 available, when clearly there is 6GB
      Any advice appreciated with thanks,
        mitu Global Moderator @Honda Z50M
        @Honda-Z50M The system reserves 5% of the available disk space to the root user, so if your partition is filled above 95%, the pi user would not be able to use the remaining space.
        Cleanup some space so the pi user can write anything on the disk, or use tune2fs to remove the 5% reserved space - but make sure you understand the consequences.
        • Honda Z50MH
          Honda Z50M
          Thanks for your reply,
          I tried deleting games (aprox 2GB) with no change and also expanded file system with no change.
          Tom
            @Honda-Z50M What do you mean 'expanded the filesystem' ?
            Can you run the 2 commands below and post the output:
            df -h
            dumpe2fs /dev/mmcblk0p2
            Honda Z50MH 1 Reply Last reply Reply Quote 0
            • Honda Z50MH
              Honda Z50M @mitu
              @mitu ok thanks I'll try later this evening and get back to you.
              Tom
              • Honda Z50MH
                Honda Z50M
                Screen shot attached
                  @Honda-Z50M Your / partition, where all the data resides, is at 100% - you have 0% usable disk space. Unless you free up some space - deleting roms or something else that's sizeable - you'll continue to have problems.
                  • Honda Z50MH
                    Honda Z50M
                    Previosuly Tried deleting roms (2GB) and that didn't work.
                      @Honda-Z50M Well, it seems I overlooked one portion of the screenshot that says 3rd Party Super Display Image. We don't support 3rd party images, you should ask the author of the image for advice.
                      • Honda Z50MH
                        Honda Z50M
                        Tries that as well and he said same thing delete roms.
                        I'll delete again and re-run the command and come back with another screen shot shortly
                        • Honda Z50MH
                          Honda Z50M
                          dev/root still at 100% 20190424_202012.jpg
                          thestargliderT 1 Reply Last reply Reply Quote 0
                          • thestargliderT
                            thestarglider @Honda Z50M
                            @Honda-Z50M I don't think you're gonna get much help here now, now that the site knows you're using a third party image.
                            Starglider!!! From Rainbird!!!
