    Roms running too fast - help a noob
    speed up
    4 Posts 3 Posters 2.5k Views
    • t_mitchT
      t_mitch
      I'm running MameLibRetro and one or two games are running way too fast. In particular pbaction will start out fine, then at a random point a few seconds or few minutes into a game, it will suddenly start to race out of control.
      Where do I start trying to figure this out? Is there a setting in RetroArch.cfg I should be looking for?
        Are you sure you don't press the 'rewind' button by mistake ? Please add more info about your system, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        t_mitchT 1 Reply Last reply Reply Quote 0
        • t_mitchT
          t_mitch @mitu
          @mitu said in Roms running too fast - help a noob:
          I don't think so, but I'll look to see what button is set for rewind.
          I found a frame rate throttle setting last night in the Retroarch GUI that was set to 0. I set it to 1 and it seems better.
          • EfriimE
            Efriim @t_mitch
            @t_mitch
            I have had this happen to me before, with one game, it fastforwards for the first minute and then just stops. I don't know what causes it. I believe it was lr-mame
