    Audio lag - Retropie x86
    audio lagaudio problemsaudio problemx86 ubuntux86
    6 Posts 2 Posters 897 Views
      Panja
      I'm running RP 4.4.12 on Ubuntu 18.04.2
      Hardware is an Intel NUC (NUC7I5BNK) which is connected to my Samsung 1080p TV through HDMI.
      After playing for some time, changing games and consoles the audio begins to stay behind/lag. It is very noticeable in games for instance when you're selecting a character.
      The character is already selected and the character select sound is coming 1 or 2 seconds behind. Also you hear it very well with the EmulationStation navigations sounds.
      Rebooting the system or changing the television input to a different input (for instance HDMI 2 or TV) and changing it back to HDMI input where RP runs 'solves' the problem. This is not really a fix, rather a workaround.
      I do not think this is a problem with Retropie perse but maybe other people here have had the same problem...? I can't be the only one with such a setup?
      Hopefully some one can help me out here?
        Try disabling PulseAudio and use Alsa directly ?
          Panja
          Sounds good. But how can I do that?
          I've disabled PulseAudio by doing:
          sudo nano /etc/pulse/client.conf
          autospawn = no
          But now I don't have sound at all.
            Panja
            Any one that can help me out?
              Remove the line with autospawn=no to get your sound back, then try the advice in https://askubuntu.com/questions/1033405/crackling-and-delayed-sound-after-upgrading-to-18-04 (3rd answer) - make sure you reboot afterwards.
                Panja
                Thanks for the reply.
                Removing the line autospawn=no enabled PulseAudio again if I'm not mistaking.
                Already tried the 3rd answer on that thread with no luck.
